Add GOTO XY widget in Web Appbuilder
7722
7
05-24-2016 12:12 PM
Status: Open
DavidWheelock
Please add a widget to ArcGIS Online Web Appbuilder to enable a user to enter an XY coordinate and then GO TO that coordinate or make it flash or label it, like in the ArcGIS Desktop software.
7 Comments
by Anonymous User
DavidWheelock
Thank you Kevin.  I already checked out Robert's nice tool month's ago, but it can only be used in Portal.  It cannot be used in ArcGIS Online which doesn't allow that sort of customization.  ESRI doesn't allow it because of the potential to inject malware into the ArcGIS Online environment.
by Anonymous User
David, yes indeed. In that case, thanks and I agree; I voted for your idea.
ClarkLangridge
This is the same as this idea I posted a while ago: https://community.esri.com/ideas/11495.  These two should be merged together.  ESRI, feel free to take mine down and add the votes to this one.
DavidWheelock
Thanks.  I don't know how ESRI goes about combining ideas into a single idea.  ESRI?
LemaoWu
Please try the Search widget. If you have configured the Esri World Geocoding Service as the search source, you can search by coordinates in the following ways:
  • x/y coordinates; x refers to longitude (east-west coordinates), and y refers to latitude (north-south coordinates)
  • Military Grid Reference System (MGRS) coordinates
  • United States National Grid (USNG) coordinates
  • Coordinates in a spatial reference specified by a well-known ID (WKID)
    The supported format is:
    X, Y: WKID. For example: -13046165.572, 4036389.847 : 102100.
More details can be found here: Search widget—Web AppBuilder for ArcGIS | ArcGIS, and findAddressCandidates—ArcGIS REST API: World Geocoding Service | ArcGIS for Developers .
JonasLeksell2
Hi Lemao,
Yes, your suggestion works fine, however this is not a easy to use or intuitive way to work with go to XY. It is such a simple tool that would make it much simple for non-map nerds to undersand. Now all need to understand x before y and then the current ?WKID?...  It is perhaps a simple workaround for us that live and breathe map technology. However I had a feeling that one of the most important use cases for the Portal and Web Appbuilder was to make it easy not to be a GIS wizzard.
