Local host/computer name/IP address
4129
05-28-2013 07:49 AM
JamalNUMAN
Legendary Contributor
I couldn�??t figure out how the published services and the deployed web application take their url. There are three possibilities:
url may contain the name of the computer
url may contain the world �??localhost�?�
url may contain the IP address
[ATTACH=CONFIG]24729[/ATTACH], [ATTACH=CONFIG]24730[/ATTACH], [ATTACH=CONFIG]24731[/ATTACH]
how to force the published service or the deployed web application to contain the IP address rather than the computer name or localhost
thank you
best
Jamal
Jamal Numan
Hector_Manuel_MartÃ_Â_nez_Luz
I don't understand the problem, can you to tell me why you wanna have everything with the IP address?.
Regards, Manuel
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Regards, Manuel
Thank you man,
Because this is much easier to approach the server machine ( to find the URLs) by its IP when working in a network (with domains)
Cheers
Sorry, I don't know how to force to use the IP number.
I am not an expert in networks, but in my case I try to avoid using numbers. The reason for that is that numbers sometimes change and that can cause a lot of problems cause you have to redirect after change. We have some problems once when our map editors use connection with numbers instead of name and after change it took us a lot of time to redirect everything. I think names are easy to handle and more stable, even you can do some manipulation local in each machine using the host file.
Sorry I can not help you.
Regards, Manuel
by Anonymous User
Not applicable
Regards, Manuel
Thank you for man for the contribution. This is useful
Best
Jamal
