External (Non ESRI) WMS in ArcGIS Viewer for Silverlight
1267
03-26-2014 04:39 AM
PriscillaCorrea
I wonder if it is possible to consume an external WMS in ArcGIS Viewer for Silverlight.
I tried using the address below, but failed.
The same address used in ArcCatalog I can see the layers.
http://mapas.mma.gov.br/cgi-bin/mapserv?map=/opt/www/html/webservices/biorregioes.map&
Thank you.
Priscilla
RonaldLopez
Consuming WMS services is possible in the Silverlight Viewer, but not out of the box.  You can utilize some of the ESRI code samples to build your own tool for doing this.
