Custom Tool - Popup Toolbar - Retrieving Popup's Graphic
1041
03-29-2012 11:02 AM
MarcusGwillim
Since it is now possible to have tools in the popup window (PopupToolbarContainer section in Tools.xml), I was wondering what is the best method to retrieve the graphic associated with the currently shown popup window. I am looking to retrieve information from the attribute dictionary of the graphic when the tool is executed.
RichZwaap
Hi Marcus:
With tools on the pop-up's toolbar, the parameter passed to the Execute and CanExecute methods is an OnClickPopUpInfo object.  So in the Execute method, you can get the feature currently shown in the pop-up like so:
public void Execute(object parameter) {     // Get feature currently shown in pop-up     OnClickPopupInfo popupInfo = parameter as OnClickPopupInfo;     Graphic currentFeature = popupInfo.PopupItem.Graphic;                        }
If you need to show the names of fields in the UI, you can get the configured field names and visibility via OnClickPopUpInfo.PopupItem.FieldInfos.
A sample that calculates service areas for the feature shown in the pop-up should be available on the code gallery within the next couple days.
Hope this helps.
RichZwaap
Hi Marcus:
Hope this helps.
MarcusGwillim
Thank you! That worked perfectly.
I can't believe I didn't think of looking at the command parameter >.<
