Changing computer name affects editing the already built web application,
4336
05-02-2013 12:39 AM
JamalNUMAN
Legendary Contributor
The computer name is changed and thus editing the built web application are affected. I�??m not able to edit web applications built by (Access is Denied):
1. ArcGIS Web Applications for the Microsoft .NET Framework (ADF)
2. ArcGIS Viewer for Silverlight
3. ArcGIS Viewer for Flex
[ATTACH=CONFIG]23925[/ATTACH], [ATTACH=CONFIG]23926[/ATTACH], [ATTACH=CONFIG]23927[/ATTACH], [ATTACH=CONFIG]23928[/ATTACH]
How to be able to edit the web application after the name of computer is changed?
Thank you
Best
Jamal
Jamal Numan
PietaSwanepoel2
Look at the KB link inside this forum post. Your problem might be related to how the security is set on server
http://forums.arcgis.com/threads/82989-Deployed-Apps-not-showing-up-in-Builder
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Many thanks guys for the help,
All what I did is giving the user �??never notify�?� property in the user account control (UAC). And it did work. I could edit the applications
[ATTACH=CONFIG]24048[/ATTACH]
What do you think?
Best
Jamal
MarcoBoeringa
What do you think?
Best
Jamal
"Never notify" means that you also will no longer receive messages when any malicious software attempts to make changes to your server. Making a more "surgical" change by following the instructions in the link posted by PietaS175 and only allow the minimum necessary to solve your issue is a more appropriate action if you like to follow "best practices".
by Anonymous User
Not applicable
Very much appreciated Marco,
Best
Jamal
