Can´t see the feature in the map  when  adding only one layer
793
09-04-2013 12:52 PM
JuliaGalindo
I am exploring the Silverlight viewer to publish a web map.  I am having problems viewing the feature layer attributes.
I have created a map service- dynamic-, it is composed of 5 layers.  I realized that if I add the dynamic map service as a layer, I can see the features in the map, I am able to configure the pop up window, but I can???t see the attribute table of each of the layers, nor can I query the layers.
If I add only one of the layer, I can query it, I can see the attribute table, but I can???t see the features in the map.
Am I doing something wrong? Or does anyone knows how should this be done?
Thank you very much for the help???
JuliaGalindo
I solved it, my problem was that I set the layer properties, in the field tab, to hide the shape field (the one with the geometry).
So when I created the map service I couldn???t get the shape.
JuliaGalindo
