ArcGIS Viewer for Silverlight 1.0 final now available!!!
9378
26
01-17-2012 10:12 AM
DerekLaw
Esri Esteemed Contributor
FYI,
ArcGIS Viewer for Silverlight 1.0 final is now available from the Resource Center.
Enjoy,
RichZwaap
Hi Zachary:
I'm assuming you mean that you want Application Builder to publish Viewer apps using a FQDN.  All you need to do to get this working is update the AppsBaseUrl in Builder's web.config with the desired URL.
ZacharyHart
Honored Contributor
Hi Zachary:
I discovered that area in the config file and have already done this and each time the software reverts it back to the machine name with port 80.
PS, since i've not heard back from anyone at support in the last few days perhaps you could take a look through the open incident? It's promising to be actually talking to a Silverlight product engineer!
RichZwaap
I'm not sure what you mean by this.  When is this value changed by the software?  I'm not aware of any time this setting is touched other than installation.
If you need to change the URL of apps that were deployed prior to updating Builder's web.config, that would require editing the Sites.xml file (in Builder\App_Data).  The web.config setting determines the base URL for newly deployed apps.
Hope that helps.
O_FallonMapsandApps
I was running the Beta version just fine.  I uninstalled the Beta version and installed the release but am getting the error:  "HTTP Error 500.0 - Internal Server Error
Calling LoadLibraryEx on ISAPI filter "C:\Windows\Microsoft.NET\Framework\v4.0.30319\\aspnet_filter.dll" failed".  Since the previous version was working ok I'm wondering what's different that would cause an issue.  Any suggestions on how to resolve this?
O_FallonMapsandApps
I figured this item out.  I'm running Server 2008 R2 with IIS 7.5.  After changing the default .Net setting from 2.0 to 4.0 (which didn't solve the problem by itself) I went into the Advanced Settings for the Silverlight Viewer and changed the Enable 32 Bit Applications setting from false to true.  After that, everything worked just fine.
JianChen
Thanks Katy, Sorry for the spam. Trying to get some sites up and running today. One other thing I can't seem to locate is the Visual Studio template. It's mentioned in the "What's new" but I can't find a link.
I got the same problem: couldn't find ArcGIS Viewer for Silverlight Project template in Visual Studio 2010 after installation. What's the solution?
KatherineDalton
Jian,
The template is only available once you've installed the ArcGIS Extensibility SDK for Silverlight. Did you get this installed successfully?
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
