Where can I find the Widget Template for Flex Viewer?
795
05-10-2012 07:36 AM
ionarawilson1
I've just downloaded the Flex Viewer 3.0 source code and I am watching a video about how to configure and customize the viewer. However they talk about a widget template and I can't find that on the project I created from the source code I downloaded. Can you guys please tell me where I can find it?
Thank you!
Here is the video and they talk about at 20:22 min
http://video.esri.com/watch/1209/configuring-and-customizing-arcgis-viewer-for-flex
ionarawilson1
By the way I see a widgettemplate.as but not a widgettemplate.mxml
BjornSvensson
There is no WidgetTemplate.mxml, only a WidgetTemplate.as:
https://github.com/ArcGIS/ArcGISViewerForFlex/tree/master/src/com/esri/viewer
The matching API Reference is at:
http://resourcesbeta.arcgis.com/en/help/flex-viewer/apiref/
ionarawilson1
But is there any template I can use to start creating a widget ?
RobertScheitlin__GISP
Ionara,
    Be sure to place Flex Viewer and/or widget questions to the Flex Viewer forum and not here on the Flex API forum:
The Flex Viewer forum where your post belongs:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
There are lots of templates all you need to do is look at any existing esri otb (out of the box) widget or one of mine (as they follow esri best practices) and use it as your template for creating your own widget.
ionarawilson1
Thank you Robert and Bjorn! I will do that!
