Use Layer List, and lose base map switching ?
2211
12-19-2010 07:59 AM
DonBarker
Map Switcher Help says:
"When designing the Viewer's capability to control the display of operational layers, it is recommended to use either the Map Switcher widget "More..." button OR the Layer List widget for a Web mapping application. It is not a best practice to have both enabled within the same Web mapping application."
But if I use just the Layer List widget, there is no option to switch base maps, far as I can tell.
Is this correct?  Or, how do I use Layer List and preserve base map switching?
Thanks.
DonBarker
I see now:
In the Map Switcher, set config to visible="false".   That removes just the "More..." buttonn for the operational layers, not the entire Switcher.
Then use the Layer List.
