<expanded everything="true">true</expanded> <collapselegends>false</collapselegends>
Monty, You can set it this way: <expanded everything="true">true</expanded> <collapselegends>false</collapselegends>
We have security enabled through AGS
Monty, What exactly do you mean by Are you using a proxy?Are you using security through tokens?Are you using SSL?Are you saying that even when you manually expand the toc items that there is no legend swatches?
Monty, Do you have the ArcGIS Service directory diabled? We are talking about ArcGIS Server 10.1 right? Do you have a sp1 installed?
Monty, So the layer that are not working for you do you have them added in the main config.xml using the http:server:6080\blah blah or the web adaptor urls?
We have security enabled through AGS for the map service
Monty, So earlier when you said you did not really mean that and you were only reffering to having the Web Adaptor installed...? You did not click on the padlock icon in ArcGIS Server manager and edit the service security?
We have internal viewers that use feature services that display the swatches, screenshot attached.
Monty, So help to understand:Are you saying the viewer that is not displaying the legends is a external/public viewer? Can you access the REST Service url form outside you intranet?
is the a way to get zoom (when clicking on result)
Monty, You definitely have me confused... The autoswitchtoscale and forcescaleonswitch are associated with the Enhanced Basemap switcher what does this have to do with the TOC Widget? What are you talking about: Are you meaning the "zoom to" or "zoom to make visible" in the TOC popup menu?
Signed in members can post, follow updates, and more. New here? Register a free account.
