I am utilizing the following code from the MapServicesWidget:case "dynamic":
var dynLayer:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(url);
dynLayer.alpha = alpha;
dynLayer.id = label;
dynLayer.name = label;
dynLayer.token = token;
dynLayer.visible = visible;
dynLayer.useMapTime = useMapTime;
dynLayer.sublayerid = sublayerid ;
dynLayer.popupconfig= popupconfig;
if (autoRefresh > 0)
setInterval(dynLayer.refresh, autoRefresh * 1000);
if (imageFormat)
dynLayer.imageFormat = imageFormat;
if (visibleLayers)
var vizLayers:Array = visibleLayers.split(",");
for (i = 0; i < vizLayers.length; i++)
vizLayers = Number(vizLayers); // convert to Numbers
dynLayer.visibleLayers = new ArrayCollection(vizLayers);
if (proxyUrl && useProxy)
dynLayer.proxyURL = proxyUrl;
map.addLayer(dynLayer);
break;
}This allows me to pick from a list, and load the service into the current map.Was wondering if there is a way to set the popupconfig file to use for each sublayer (similar to the config.xml file) so that when i load the service with the widget (something like in red above), it will recongnize the appropriate popupconfig.xml file?Thanks for any suggestions,R_
