RPC Fault faultString="Unable to complete operation." faultCode="400" ...
7150
10
04-24-2013 08:31 AM
brahimmaylal
Hi;
I have a problem with the widget search; when I use a service published in arcgise server 10 it worked good but when I use the same widget with a sevice in arcgis server 10.1 it give me an error when i do a search by attribute; [RPC Fault faultString="Unable to complete operation." faultCode="400" faultDetail=""]
[ATTACH=CONFIG]23742[/ATTACH]
Someone can help me
JohnGravois
with regard to every other query failing, this is a 10.1 SP1 ArcGIS Server specific bug and affects identical queries fired sequentially using a GET.
[NIM086349 Alternate Query (Get) requests to some map services fail in ArcGIS Server 10.1 SP1.]
The problem has been fixed in 10.2. sorry for the inconvenience.
