Request for enhancement of TOC widget 3.0i
1080
03-28-2014 08:56 AM
BarnabyRockwell
Hi Robert,
My operational, public server is running Server 10.01 + Flex 3.0.  The Flex app includes TOC widget 3.0i.  The only problem with it is that the small down-arrow "Zoom to" buttons are not bound to the right-hand edge of the TOC widget window as they are in the Enhanced Layer List widget.
[ATTACH=CONFIG]32600[/ATTACH]
http://cmerwebmap.cr.usgs.gov/flexviewers/min7_demo_pub/
I'm sure that you have more important things to do, but would it be a lot of work to modify the widget 3.0i version to bind those buttons to the right-hand edge of the window?  With that modification, the widget is basically as good as the current Enhanced Layer List widget.
Another question/alternative:  do you recommend that I upgrade the Flex App Builder from 3.0 to a higher version on my server (ArcGIS Server 10.01)?  Put another way, what is the most recent version of the App Builder which will work for Server 10.01?  It is a real hassle to upgrade my server to 10.2.1.
Best regards,
Barnaby
RobertScheitlin__GISP
Barnaby,
   As far as dynamic resizing of the widget, No. But you can add the width to the widget in the main config.xml as I said and it will bind the width of the TOC component to the width of the the widget INITALLY.
<widget url="widgets/TOC/TOCWidget.swf" config="widgets/TOC/TOCWidget_2.xml" label="Table of Contents and Explanation" icon="assets/images/Legend32.png" preload="open" width="420"/>
Barnaby,
   I don't do updates to older versions of widgets (especially 6 minor versions behind). But I do have some suggestions. The actual TOC rending is bound to the widgets width set in the main config.xml. So do you a width attribute set on the toc widget in the main config.xml?
As far as should you update to a newer version of the viewer, Yes. I unaware of any version of the viewer that is bound to a specific ArcGIS Server version, (i.e. you can use Viewer 3.6 with Server 10.01). The downside is that some functionality will not be there for certain things.
There has been SO Many great improvement in ArcGIS Server since 10.01, in my opinion it is well worth it.
BarnabyRockwell
Hi Robert,
Here is the TOC widget entry from config.xml:
    <widgetcontainer layout="float">
        <widget url="widgets/TOC/TOCWidget.swf" config="widgets/TOC/TOCWidget_2.xml" label="Table of Contents and Explanation" icon="assets/images/Legend32.png" preload="open"/>
I see no width attribute setting.  I never modified the widget settings, so they are all default AFAIK.
Here is the active TOCWidget xml:
<?xml version="1.0" ?>
<configuration>
    <labels>
        <visibilitylabel>Layer Visibility</visibilitylabel>
        <zoomtoextent>Zoom To Layer Extent</zoomtoextent>
        <expandall>Expand All Layers</expandall>
        <collapseall>Collapse All Layers</collapseall>
        <zoomtomakevisible>Zoom To Make Visible</zoomtomakevisible>
        <generatinglegendmsg>Generating TOC Legend</generatinglegendmsg>
    </labels>
    <tocsettings>
        <expanded everything="false">true</expanded>
        <collapselegends>true</collapselegends>
        <disablezoomtomenuoption>false</disablezoomtomenuoption>
    </tocsettings>
    <legendtimeout>60</legendtimeout>
    <excludelayers>
        <excludelayer mapservice="Symbols"/>
        <excludelayer mapservice="Utilities">8</excludelayer>
    </excludelayers>
    <excludegraphiclayers>true</excludegraphiclayers>
    <excludebasemaplayers>true</excludebasemaplayers>
    <usenewesridescription>false</usenewesridescription>
</configuration>
Do you know of some way I can edit the above XML to bind the zoom buttons to the right-hand side of widget window?
I use server 10.2.1 on another, internal server, and it is great all around.  The time to upgrade my operational box is drawing nigh.
Barnaby
Barnaby,
BarnabyRockwell
YES!  That is perfect.  I set width to 600.  Done deal.
Many thanks,
Barnaby
