In ArcGIS viewer for flex we have configured our search and identify widgets to mark polygons and lines with the color red. So if I select a polygon or a line on a map using the Identify widget, the polygon is marked using a red outline and red infill with a bit of transparency applied to them. If I print the map as PDF I get the same result, as expected.
If I do the same thing but with the search widget, I again get the expected red outline with red infill with the correct transparency level applied to them. But if I print that map, I get a cyan outline and solid red infill.
How can we make the printout of a search result the same as what we have onscreen?
ArcGIS Viewer for Flex 3.4
ArcGIS 10.1
