Print Widget overlabeling Dynamic Services
575
01-14-2014 05:45 AM
StevenMenefee1
We are using the 3.4 print service widget (using our custom templates), and it appears as though it is "overlabeling" the dynamic services.  My programmer told me it appears as though it is rendering the map in four quadrants, and labeling each quadrant separately, which is causing duplicate labels.
Has anyone else ran into this and is there a quick fix?  I've attached a picture as an example (the precincts and commissioner names in yellow should only be labeling once...like they are in the actual web app) Thanks!
RobertScheitlin__GISP
Steven,
   Sure find the answer in this thread:
http://forums.arcgis.com/threads/100098-strange-labeling-on-print-in-3.6
StevenMenefee1
Great, thanks Robert!
StevenMenefee1
Any clue of when or if they're going to fix this bug?  Setting the DPI that low makes our printouts look pretty bad...
