Popup with relates vertical scroll bar obscures data
3962
6
03-25-2013 12:28 PM
JaredYost
I have relates attached to my parcels.  To access the data i have selected show relate in the popup wizard (arcgis Viewer for flex 3.2) The vertical scroll bar obscures approximately 6 characters worth of data when the string is wider than the window.  I am happy with the wrap around as long as it still shows all the information.
Thoughts?
[ATTACH=CONFIG]22945[/ATTACH]
JaredYost
Yes 3.3 fixed the problem. Much better now.
Wee_LikLau
I have the same problem over here. Can we make some tweak on the uncompiled version to increase the size of the relate dialogue?
Please help...
GISDev1
Can you post your popup xml?
JaredYost
<?xml version="1.0" ?>
<configuration>
  <fields>
    <field name="PID" alias="PID" visible="true" />
  </fields>
  <showattachments>false</showattachments>
  <showrelatedrecords>true</showrelatedrecords>
</configuration>
ScottMcGee
The new Flex 3.3 upgrade solves this problem. The Related Records window now has a horizontal scroll bar that will let you see the entire text of the fields in the related tables.
JaredYost
AllisonKampbell
Thoughts?
Hi:  I just had to ask how did you get the buttons that show the related records to appear in the related records pop-up?  Sorry that this is unrelated to your original question.
Allison
