PopUp showing title twice
791
01-17-2012 02:27 AM
LokeshZopay
I have configured popup in my main config.xml which shows up properly.
i have created a infoWindow on click of a cluster graphic. Once i click on the cluster graphic the infoWindow shows up, but when i click on graphic to get the popup window it shows label twice i.e it shows label of infoWindow and title of popup window.
Can any one suggest how do i remove the label on the popup ??
RobertScheitlin__GISP
Lokesh,
    You need to post all Flex Viewer and/or widget questions to the Flex Viewer forum here:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
You need to look at this like for a possible workaround to the issue you are seeing.
http://jeffgermain.wordpress.com/2011/05/05/bug-in-arcgis-api-for-flex-infowindow-workaround/
