Popup formatting dates and numbers in FlexViewer 2.3
5452
15
04-19-2011 11:33 AM
JosVroegop
I am looking for information on how to use date and number formatting in the flexviewer's 2.3 popups.
There is one example that uses the date formatter but i can't seem to get it to work in my own popups. Can anyone help me out? Thanx in advance.
RobertScheitlin__GISP
JosVroegop
Thanks, i found what i was looking for. I added an example.
<fields>
<field name="Number" " visible="true">
        <format precision="3"/>
        </field>
<field name="Date" visible="true">
        <format dateformat="DD-MM-YYYY"/>
        </field>
</fields>
JonFisher
I've been having trouble turning off the thousand separator. I'm using the syntax:
<field name="TR_IFMS_ID" alias="Tract ID"  visible="true">
         <format useThousandsSeparator="false"/>
        </field>
But the field is still showing up with the thousand separators. Any tips?
MehulChoksey
try all lowercase and note single s after thousand.  usethousandseparator
JonFisher
Thanks, I had the extra s and capitalization since that's what the API page lists. I changed it to:
         <format usethousandseparator="false"/>
        </field>
But it's still displaying the comma thousand separators (see attached). Can others get this to work properly? The field is esriFieldTypeDouble in case that makes a difference. I never had this problem with thousand separators until the 2.3 upgrade.
Jon,
   The thousands separator is a bug.
   If you are one that is using the FlexViewer source code than you can fix the BUG that is causing this.
In the MapManager.mxml line 980.
is Currently (BUG):
pFieldInfo.format.useThousandsSeparator = fields.format.@usethousandseparator;
needs to be (FIX):
pFieldInfo.format.useThousandsSeparator = fields.format.@usethousandseparator == "true";
JonFisher
That fixed it, thanks so much!
DerekHunter
Wondering correct use of this for use in FeatureTooltip widget.  My date field for given date (6/8/2011) displays as 1307491200000.  Below is the xml for the widget.
<configuration>
<layers>
        <layer>
            <name>Crime</name>
            <fields>Crime_Date,PD_ID,Street,Description</fields>
        </layer>
    </layers>
</configuration>
Derek,
   I don't do any special formatting of returned values in this widget and esri returns date field values for REST as a UTC number.
