Pass current view extents (or center) from map to URL in header link
3008
8
10-20-2014 03:08 PM
DerekHunter2
Is it possible to include a headerwidget link URL (to a another flex viewer) that appends the current center or extent to the URL.  This is in order to send the user from the current viewer to another viewer zoomed to that same extent.
RobertScheitlin__GISP
Derek,
  Here is a compiled widget for it then. I need another widget to support like I need a hole in my head so I will likely not post this anywhere but here.
This is a UI section widget, so it does NOT go in the normal widget container, it belongs with the OverviewMapWidget, HeaderControllerWidget, etc.
<widget left="3" bottom="45"   config="widgets/shareMap/shareMapWidget.xml" url="widgets/shareMap/shareMapWidget.swf"/>
Derek,
  Here is my urlDialog.mxl code that I call from a button in a widget (not a header link like you asked).
<?xml version="1.0" encoding="utf-8"?>
<s:BorderContainer xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   width="400" height="175"
                   creationComplete="Init()"
                   styleName="WidgetCanvas">
    <fx:Script>
        <![CDATA[
            import com.esri.ags.geometry.Extent;
            import mx.managers.PopUpManager;
            [Bindable] public var sPPIN:String = "";
            [Bindable] private var _Url:String = "";
            [Bindable] public var _extent:Extent;
            private function close():void
                PopUpManager.removePopUp(this);
            private function Init():void
                _Url = this.parentApplication.url.substring(0,this.parentApplication.url.length - 3) + "html";
                _Url += "?PPIN=" + sPPIN;
                //_Url += "&EXT=" + _extent.xmin.toFixed(4) + "," + _extent.ymin.toFixed(4) + "," + _extent.xmax.toFixed(4) + "," + _extent.ymax.toFixed(4);
    </fx:Script>
    <s:Label x="10" y="10" width="300" maxHeight="60" styleName="WidgetText"
             text="This is the URL that you can copy and email to someone so they can paste it into their browser and see the parcel you are viewing."/>
    <s:TextArea left="10" right="10" bottom="10" height="93" alpha="1.0"
                fontFamily="Arial" fontSize="10" text="{_Url}" />
    <s:Line x="10" y="61" width="95%">
        <s:stroke>
            <s:SolidColorStroke color="0xffffff" weight="1"/>
        </s:stroke>
    </s:Line>
    <s:Image right="10" top="10" width="20" height="20" buttonMode="true" click="close()"
              source="assets/images/w_close.png" toolTip="Close" useHandCursor="true"/>
</s:BorderContainer>
and my code to call this dialog:
private var container:ViewerContainer = ViewerContainer.getInstance();
private var urlWindow:urlDialog;
            private function getURL(event:Event):void {
                var parcelResult:ParcelResult = ItemRenderer(event.target).data as ParcelResult;
                urlWindow = new urlDialog();
                urlWindow.x = (container.mapManager.map.width / 2) - (urlWindow.width / 2)
                urlWindow.y = (container.mapManager.map.height / 2) - (urlWindow.height / 2)
                urlWindow.sPPIN = parcelResult.ppin;
                urlWindow._extent = container.mapManager.map.extent;
                PopUpManager.addPopUp(urlWindow, container.mapManager.map, true);
                PopUpManager.centerPopUp(urlWindow);
DerekHunter2
Thanks Robert.
I was thinking it would be less complex.  I'm sure this is simple for a developer, but beyond my capabilities.  Not sure how to implement that.
Thanks for the information though.
Derek,
DerekHunter2
Thanks.  How would one hard code in an address other than the viewer they are currently in?  I am trying to take a user from a tile-based viewer to a dynamic viewer so they can see the most current data.
Derek,
   I can add that feature. You should mark this as answered and replies that you get in GeoNet as helpful if they were helpful to you.
DerekHunter2
Awesome.  Is that something I can edit in Flash Builder?
Here is the updated code: Just uncomment the alternatebaseurl tag in the XML and replace with your desired URL
DerekHunter2
As always thanks for your help.  Your help is invaluable.
Since I already have a config appended to the base URL (/index.html?config=new_config.xml) is there a way to embed the & to your base url paramter for the extent?
Could you also suggest how tool could be made into a button that just takes the user to that extent of the other viewer without having to copy and past the url into another browser tab?
