New User / Old Environment
3716
8
01-13-2014 12:00 PM
by Anonymous User
Not applicable
Original User: bokeefe
[ATTACH=CONFIG]30476[/ATTACH]
I came into a new position and inherited a previously setup ArcGIS / Flex environment. I'm trying to get up to speed on Flex with ArcGIS and I wanted to generate a new environment. I walked through the ArcGIS API for Flex steps and create GISDev. TulsaDefaultMap was previously installed and setup.
As you can see... TulsaDefaultMap "HAS" the correct folders (widgets, popups, etc) but my new one doesn't.
What (am I doing/have I done) wrong here?
Any ideas?
by Anonymous User
Not applicable
Original User: ad_giles@hotmail.com
Brian,
That looks like the api you are trying to add as a project, not the flex viewer source code, download the following and try again:
https://github.com/Esri/arcgis-viewer-flex/archive/master.zip
Regards
Anthony
by Anonymous User
Not applicable
Brian,
Have you downloaded the relevant API .swf and placed it in your libs folder
Regards
Anthony
BrianO_keefe
Honored Contributor
by Anonymous User
Not applicable
What are the error messages you are getting?
BrianO_keefe
Honored Contributor
No error messages, just no folders called popups, widgets, etc.
What I want is what is boxed in green...
What I have is boxed in red...
[ATTACH=CONFIG]30481[/ATTACH]
by Anonymous User
Not applicable
Brian,
I am not quite sure what you have done, have you created a new project in flex builder or did you import a project using the following steps:
1.In Adobe Flash Builder 4.6 or 4.7, go to "File" -> "Import Flash Builder project...", then depending on whether you have a zip file or not, follow step 2 or 3.
2.If you downloaded the zip file: i.Keep "File" option selected, click "Browse..." button. Select the downloaded flexviewer-3.[]-src.zip file, for example "C:\Documents and Settings\jack\My Documents\flexviewer-3.[]-src.zip".
ii."Extract new project to:" textbox will be automatically set to location where the project source will reside, e.g. "C:\Documents and Settings\jack\Adobe Flash Builder 4.7\FlexViewer.
3.If you cloned and/or forked the repo: i.Select "Project folder", click "Browse..." button and navigate to your local repo, for example C:\Users\jack\Documents\GitHub\arcgis-viewer-flex.
4.Click "Finish" button. Project will be created and displayed in the Package Explorer window of Adobe Flash Builder, e.g. in this case FlexViewer.
5.If prompted to upgrade the project (because it was created with a previous version of Flash Builder), click "OK"
6.If prompted to choose Flex SDK version, select "Flex 4.6.0" or higher.
7.Download API Library from http://links.esri.com/flex-api/latest-download. Unzip it.
8.Go to "Project" -> "Properties" -> "Flex Build Path".
9.Click "Add SWC" and navigate to the agslib-3.
  • -[YYYY-MM-DD].swc API library file.
  • Regards
    Anthony
    BrianO_keefe
    Honored Contributor
    Ok... I 'tried' to import into Flash Builder and this is what I see...
    [ATTACH=CONFIG]30483[/ATTACH]
    It won't let me.
    by Anonymous User
    Not applicable
    Brian,
    Regards
    Anthony
    BrianO_keefe
    Honored Contributor
    FIXED!
    Ok... It's been a good 6 years since I last touched Flex and then I was in a mix of command line compiling and Eclipse hack-thrus but it's starting to come back, just a little tho... MXML's are still causing me headaches...
    BUT... the initial problem HAS BEEN SOLVED!
    Thank you kindly!
