I came into a new position and inherited a previously setup ArcGIS / Flex environment. I'm trying to get up to speed on Flex with ArcGIS and I wanted to generate a new environment. I walked through the ArcGIS API for Flex steps and create GISDev. TulsaDefaultMap was previously installed and setup.
As you can see... TulsaDefaultMap "HAS" the correct folders (widgets, popups, etc) but my new one doesn't.
What (am I doing/have I done) wrong here? Any ideas?
I am not quite sure what you have done, have you created a new project in flex builder or did you import a project using the following steps:
1.In Adobe Flash Builder 4.6 or 4.7, go to "File" -> "Import Flash Builder project...", then depending on whether you have a zip file or not, follow step 2 or 3.
2.If you downloaded the zip file: i.Keep "File" option selected, click "Browse..." button. Select the downloaded flexviewer-3.[]-src.zip file, for example "C:\Documents and Settings\jack\My Documents\flexviewer-3.[]-src.zip". ii."Extract new project to:" textbox will be automatically set to location where the project source will reside, e.g. "C:\Documents and Settings\jack\Adobe Flash Builder 4.7\FlexViewer. 3.If you cloned and/or forked the repo: i.Select "Project folder", click "Browse..." button and navigate to your local repo, for example C:\Users\jack\Documents\GitHub\arcgis-viewer-flex. 4.Click "Finish" button. Project will be created and displayed in the Package Explorer window of Adobe Flash Builder, e.g. in this case FlexViewer.
5.If prompted to upgrade the project (because it was created with a previous version of Flash Builder), click "OK"
6.If prompted to choose Flex SDK version, select "Flex 4.6.0" or higher.
Ok... It's been a good 6 years since I last touched Flex and then I was in a mix of command line compiling and Eclipse hack-thrus but it's starting to come back, just a little tho... MXML's are still causing me headaches...
BUT... the initial problem HAS BEEN SOLVED! Thank you kindly!
