name tag for headercontrollerwidget search not working completely?
2126
07-16-2014 03:49 PM
RhettZufelt
MVP Notable Contributor
From the headercontroller documentation:
<name>Name given to the layer when displaying the search results, default behavior is to display the layername. [Added at 3.2]
Seems that when I put the <name> tag in my headercontrollerwidget.xml it appends the name value after the layername, not instead.
         <mapservice>
            <url>http://arcgisprod01.ci.richland.wa.us/ArcGIS/rest/services/PublicWorks/SDmanholes2Bnumbered/MapServe...</url>
            <layerids>2,3</layerids>
            <searchfields>FacilityID</searchfields>
            <name>Storm Feature</name>
         </mapservice>
Am I missing something here, or is it going to still add the layername as well as any name tag values?
R_
Using OTB compiled FV3.6
RobertScheitlin__GISP
Rhett,
   That is correct it is just designed to append to the features layer name to let you know what map service configuration the result is coming from. I believe this was designed to allow you to distinguish result from one map service or another if you have multiple configured.
Robert
Rhett,
Robert
