Merge Selected Features Greyed-Out/Unavailable
9669
08-26-2013 05:34 AM
ColeS
On the edit toolbar, the merge tool is unavailable even when set to "On."  I have two features from the same feature class selected (I am able to edit the attributes, add, delete, update geometry) but I am unable to merge them into one feature.
Has anyone else run into this?  Any ideas?
Thanks!
[ATTACH=CONFIG]26966[/ATTACH]
DanielStauning
It seems that this is works for polygon features, can you confirm what kind of data you're working with? Are they polyline features?
- Daniel
ColeS
Yes, they are polyline features.  The merge works for polygons.
Thanks.
ColeS
Is this a limitation of the API in general?
Limitations/Quirks:
-Polygons are not simplified when editing existing features.
-Merging is only supported for polygons.
-CompositeSymbol works with the Editor (as of version 2.4) but no swatches are shown as the CompositeSymbol does not support swatches.
https://developers.arcgis.com/en/flex/api-reference/com/esri/ags/components/Editor.html
