LODs and disappearing basemaps
939
02-01-2012 06:07 AM
AndreaGrygo
I am using Bing, Esri, and OSM basemaps, along with a tiled custom basemap (in Web Mercator).  Yesterday all of the basemaps would not display starting at 1:36,112.  I added the LOD scales from my custom basemap and the basemaps now display.
Do LODs always need to be included in the config file to prevent this issue from happening?
Thanks-
RobertScheitlin__GISP
Andrea,
   The LODs from the first Basemap are the ones that are used for the map. So if you have another layer that needs to add more LODs then yes you have to add the LODS to the config.
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
