little question: property 'visiblelayers' not recognized?
2530
04-09-2012 11:38 AM
LeenD_hondt
I am trying to have make an application where the user can turn on/off the dynamiclayer of a mapservice. A very small question regarding this.
In my config file I have set 1 of the 2 layers visible using the visiblelayers property:
        <operationallayers>          <layer label="gpsTrack" type="dynamic" visible="true" visiblelayers="1" url="http://176.34.114.255/ArcGIS/rest/services/fleetPoc/FleettracksJanLeen/MapServer"/>          </operationallayers>
Then, in my mxml of my widget, I want that the user, once he checks an option of a dropdownlist, he can see that layer visible. There are only two layers. At startup, I put "1" visible (as mentioned above), but then the user should be able to make the second one visible (and the first one invisible) and vice versa. I do not think it can be very difficult, but the issue is that in my mxml, he does not recognize the property 'visiblelayers'.
protected function myDDL_changeHandler(event:IndexChangeEvent):void    {     var dyn:ArcGISDynamicMapServiceLayer= map.getLayer("gpsTrack") as ArcGISDynamicMapServiceLayer;     var visLayers:ArrayCollection = dyn.visibleLayers;      if (myDDL.selectedItem.subject == "Track")      {       visLayers.removeItemAt(2);      visLayers.addItem(1);      dyn.visibleLayers=visLayers;      dyn.refresh();           }      else if (myDDL.selectedItem.subject == "Elevation")      {       visLayers.removeItemAt(1);      visLayers.addItem(2);      dyn.visibleLayers=visLayers;      dyn.refresh();           }
However, the compiler gives an error: "RangeError: Index '1' specified is out of bounds."
But my service has the following layers:
    VehicleTracks (0)
        Tracks (1)
        TracksElevation (2)
Any tips to resolve this issue?
Thanks a lot in advance!
Kindly,
Leen
IvanBespalov
Leen,
Here is about 100 sublayers - in this sample i play with legend, but you can find some layer switching visibility code 2. (sources)
protected function myDDL_changeHandler(event:IndexChangeEvent):void {  var dyn:ArcGISDynamicMapServiceLayer= map.getLayer("gpsTrack") as ArcGISDynamicMapServiceLayer;  // var visLayers:ArrayCollection = dyn.visibleLayers;   if (myDDL.selectedItem.subject == "Track")   {    // visLayers.removeItemAt(2);                 var visLayers:ArrayCollection = new ArrayCollection();                 visLayers.addItem(1);    dyn.visibleLayers = visLayers;   dyn.refresh();    }   else if (myDDL.selectedItem.subject == "Elevation")   {    // visLayers.removeItemAt(1);                 var visLayers:ArrayCollection = new ArrayCollection();   visLayers.addItem(2);    dyn.visibleLayers=visLayers;   dyn.refresh();     } }
you can't remove item at 100, if your collection length is 50!
somearraycollection.removeItemAt(item index);
to check item exists you need to get its index:
var itemIndex:int = somearraycollection.getItemIndex(item);
so, if itemIndex not equals "-1" means what item exists, you can remove existing item:
somearraycollection.removeItemAt(itemIndex);
IvanBespalov
Leen,
LeenD_hondt
Thank you soooo much! It works!!
(can you just explain why? why can't the arraycollection be created at front and be updated within the if.. else.. loop?)
Thanks!
Leen,
Here is about 100 sublayers - in this   sample i play with legend, but you can find some layer switching visibility code 2. (  sources
  dyn.refresh();
  dyn.refresh();
IvanBespalov
Yes, ArrayCollection can be created at front and be updated within the if.. else.. loop...
        // remove item = 2
        var indexOfItemToRemove:int = visLayers.getItemIndex(2);
        if (indexOfItemToRemove != -1)
             visLayers.removeItemAt(indexOfItemToRemove);
        // add item = 1
        dyn.refresh();
        // remove item = 1
        var indexOfItemToRemove:int = visLayers.getItemIndex(1);
        // add item = 2
        dyn.refresh();
1 more time, Yes, ArrayCollection can be created at front and be updated within the if.. else.. loop..., but can you answer me now, why is it needed (in your situation)?
        dyn.visibleLayers = new ArrayCollection([1]); // set collection of visible layers
        dyn.refresh();
        dyn.visibleLayers = new ArrayCollection([2]); // set collection of visible layers
        dyn.refresh();
LeenD_hondt
Hi, thanks. Well, the reason why I wanted to know is because I got a warning when I used your former code. On the second statement of the var vislayers it informed me:
"Duplicate variable definition." And next to that, I try to clean up my code as much as possible.
Thanks again! (your code with the legend is also very helpfull!)
        // remove item = 2
        // add item = 1
        // remove item = 1
        // add item = 2
    dyn.refresh();
    dyn.refresh();
