Layers Manager Widget by Odoe How do I change the color of the layer's text?
909
03-03-2011 09:51 AM
City_of_Port_Angeles_GIS
Hi all,
   I tried to implement Odoe's Layers Manager Widget by Odoe but the names of all my layers are in a light grey color while the background is in a grey color just slightly darker than the text. I have a tough time reading the names. How can I change the text color to be darker, preferably black?
Billy
ReneRubalcava
Esri Frequent Contributor
I've been meaning to fix the itemRenderers for this.
Probably best solution would be to open these 2 itemRenderers in the source.
LayerListItemRenderer.mxml
LayerListDynamicItemRenderer.mxml
change the alpha value of the <s:Rect> to 0.
 <s:Rect left="0"
   right="0"
   top="0"
   bottom="0">
  <s:fill>
   <s:SolidColor color="#F0F8FF"
        alpha="0" /> <!-- change this from 0.6 t0 0 -->
  </s:fill>
 </s:Rect>
I'll update the source and compiled swc in zip after lunch today.
ReneRubalcava
Ok, it's updated.
http://www.arcgis.com/home/item.html?id=bed0140d93ee49d8b8f8f1a5b7310c6f
You can check out a demo here.
http://odoe.net/thelab/flex/flexviewer/index.html?config=config-layersmanager.xml
If you really wanted to change the text color, you could edit the LegendManageraSkin.mxml as such.
<s:Scroller height="100%"
   width="100%">
<!-- add a color value for the DataGroup -->
 <s:DataGroup id="legendDataGroup" color="0xffff00"
     itemRendererFunction="itemRenFunc">
  <s:layout>
   <s:VerticalLayout gap="2"
         horizontalAlign="justify" />
  </s:layout>
 </s:DataGroup>
</s:Scroller>
I've thought about swf loadable stylesheets, but wasn't sure about it for widgets. (i.e. compile css to swf for widget swfs)
Thanks Rene, that works great.
Billy
