config.xml file contains information about layers configuration something like this: <basemaps> <layer label="Streets" type="tiled" visible="true" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <layer label="Aerial" type="tiled" visible="false" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <layer label="Topo" type="tiled" visible="false" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> </basemaps> <operationallayers> <layer label="Boundaries and Places" type="tiled" visible="false" url="http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places_Alternate/MapServer"/> <layer label="Fires" type="feature" visible="false" alpha="1" info="widgets/InfoTemplates/SimpleInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/IWT_Fires.xml" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/> </operationallayers> add imageFormat property to your layer: <basemaps> <layer label="Streets" type="tiled" visible="true" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"/> <layer label="Aerial" type="tiled" visible="false" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <layer label="Topo" type="tiled" visible="false" alpha="1" url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> </basemaps> <operationallayers> <layer label="Boundaries and Places" type="tiled" visible="false" url="http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places_Alternate/MapServer"/> <layer label="Fires" type="feature" visible="false" alpha="1" info="widgets/InfoTemplates/SimpleInfoWinWidget.swf" infoconfig="widgets/InfoTemplates/IWT_Fires.xml" url="http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Fire/Sheep/FeatureServer/0"/> <layer label="MyLayer" type="dynamic" visible="true" imageFormat="png32" url="my layer url"/> </operationallayers> Find MapManager.mxml in FlexViewer. This file contains layes adding business logic. As you see, only such types of layers support imageFormat proprty: "dynamic", "image", "arcims", "wms". You can change/add this property in this file. More information in Flex API reference.
Find MapManager.mxml in FlexViewer. This file contains layes adding business logic.As you see, only such types of layers support imageFormat proprty: "dynamic", "image", "arcims", "wms".You can change/add this property in this file.More information in Flex API reference.
<operationallayers> <layer label="Meters" type="dynamic" visible="true" imageFormat="png32" url="http://ags2.cdm.com/arcgis/rest/services/Meters/MapServer"> <sublayer id="0" popupconfig="popups/PopUp_AMR.xml"/> <sublayer id="1" popupconfig="popups/PopUp_AMR_PressureZones.xml"/> </layer> </operationallayers>
If you only have a single layer in your map service you should turn off that 50% transparency as it serves no real purpose and may slow things down.
var dynLayer:ArcGISDynamicMapServiceLayer = new ArcGISDynamicMapServiceLayer(url); // set properties dynLayer.imageFormat = "PNG32"; // add layer to map map.addLayer(dynLayer);
<esri:Map id="myMap"> <esri:ArcGISDynamicMapServiceLayer id="dynamicLayer" imageFormat="png32" url="{dynamicLayerUrl}"/> </esri:Map>
in my .msd file i have a polygon layer set to 50% transparency.when i turn it on in the flex 2.2 viewer it is not transparent.in the rest/services list the transparency is recorded.any thoughts about why this happening??thanks
Signed in members can post, follow updates, and more. New here? Register a free account.
