Layer is not shown in the TOC after load shapefile
5171
21
12-13-2012 09:44 AM
LeonardoAraújo
Hi all,
I'm trying to use the Load Shapefile widget (http://www.arcgis.com/home/item.html?id=bc6a88cf51364d9ea767347954363d7d) and am having a problem after loading a file. The features are loaded successfully but the TOC does not display the new layer. Could anyone help me on this?
LeonardoAraújo
Leonardo,
   You are meaning to say Geometry Service right?... And you have you Flex Viewers main config.xml point to your Geometry Service?
Right, I meant Geometry Service. I'm pointing to my own service in the config.xml file.
RobertScheitlin__GISP
Leonardo,
   Can you try and use my live preview site to test your shapefile zip?
LeonardoAraújo
Leonardo,
I've done this and it worked perfectly.
Leonardo,
   Are you using ArcGIS Viewer for Flex 3.0 and Adobe Flex SDK 4.6?
LeonardoAraújo
Leonardo,
Yes. agslib-3.0-2012-06-06 and sdk 4.6.0
Leonardo,
  Can you try pointing your main config.xml  to this instead of your?
<geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer" />
LeonardoAraújo
Leonardo,
I did a deploy the application to my web server and there everything was fine. For some reason I am not able to run the application from my IDE.
Leonardo,
  Strange I run from my Flash Builder IDE all the time. Do you have your Flex Build Path in your project pointing to an"Output folder URL"?
LeonardoAraújo
Leonardo,
No, I don't have any application server pointed in Flex server tab property of my my application.
PetraKrsnik
I'm also having problems showing layer in the TOC. I use ArcGIS Viewer for Flex 3.0 and Adobe Flex SDK 4.6.  I use uncompiled versions of widgets. When I upload a .zip file it reproject and shows on the map correctly, but it does not show up in TOC. I get �??Generating TOC Legend�?� message which never ends. It does not stop showing this message even after I remove shape file. Otherwise TOC widget works perfectly. I tried using layer list and my shapefile does show up there. Any idea how to fix this?
Thank you,
Petra
