jQuery Accordion Banner in Flex Viewer
2051
04-01-2011 08:16 AM
WillHughes1
I am using a jQuery horizontal accordion from http://www.dynamicdrive.com/dynamicindex17/haccordion.htm
and would like to add it the flex view GUI either at the top banner where the widget icons are located, or somewhere else in the flexviewer layout.
Is it possible to integrate something like this into the Flex Viewer?
Thanks.
Will
AlexJones
Have you considered using the native flex accordion? If you check out tour de flex there are also a couple of custom accordions that are written in mxml/actionscript that would be a lot easier to incorporate into the viewer. If you have the uncompiled code you can definitely add as you see fit. It will be hard to say exactly how without knowing what you are trying to accomplish. If you have not already check out the tour de flex for sample code.
http://www.adobe.com/devnet/flex/tourdeflex.html
