Is there a maximum # of attachments that can be added per feature in the Edit Widget?
930
12-10-2012 12:36 PM
JanieGoddard
   We would like to add a number of attachments to a feature in the Edit Widget. We were concerned as to how many attachments can be added per feature? It would probably not be greater than twenty attachments.
Janie
RobertScheitlin__GISP
Janie,
   There is no limit that I am aware of. But maybe someone from the Flex team can confrim.
JanieGoddard
Robert,
  Thank you so much for your answer. Once again you are there for us.
Janie
HeatherGonzago
Robert,
Janie
Hi Janie,
There is no set limit to the amount, although there is a limit to the size of the attachment. The maximum size is set to ~2GB.
HTH
JanieGoddard
Thanks Heather! Janie
