Identify Widget v3.6.5 - Copy results to clipboard question
2530
12-12-2014 10:29 AM
BrianFausel
When using the Robert Scheitlin, GISP Flex Viewer Identify Widget v3.6.5, there is a button that copies results to clipboard.  It returns the layer name and column name along with attribute data, which is great in many cases.  However, I have a situation where I just want to copy the attribute value.  Is this possible?  An example:
Copy-paste normally returns this result:
Water Lateral
I only want to return this:
23NW048
Thanks!
RobertScheitlin__GISP
Brian,
   No that is not an option/configurable.
Brian,
BrianFausel
Thanks for the confirmation.
RhettZufelt
MVP Notable Contributor
Not exactly what you are asking for, but one way is to select and <Ctrl><C> the value from the popup.  There is no right-click copy option, but the <Ctrl><C> works.
R_
BrianFausel
Yes, that would typically work, but not in this case.  Thanks for the response.
