Hi
I have 32 layers in my flex application.Is there any way to make groups of these layers like ArcGIS Desktop?
I can not do this in ARCGIS DESKTOP, because some layers are cashed and some layers are dynamic.
Regards
Yes, the config that is supplied with the widget works with the default config file when you download the viewer using the fires and demographic layers
Anjelina,
Many have requested this but it is not an option in Flex Viewer. There was a widget back several versions ago that sort of did this but it is not compatible with the current versions.
What is the name of that widget?
If it is not compatible with flex 3.6, is there other solution?
the the source code for the widget can be found here:
WestonSF/ArcGISFlexViewerTOCGroupWidget · GitHub
but it will require you to have the ability to compile source code
Something like the group toc but no there is no solution for 3.6
Do you can help me more, or write a widget?
Angelina,
Nope this one is way to complicated and involved.
I,m looking for a expert flex developer. my email is:
anjelinaponkerat@gmail.com
I have recompiled the widget for 3.6 (attached zip file). You will not be able to use it with the web app builder so you will have to add the widget to the config file manually:
<widget label="Layers" right="10" bottom="10" preload="open"
icon="assets/images/Legend32.png"
config="widgets/TOCGroup/TOCGroupWidget.xml"
url="widgets/TOCGroup/TOCGroupWidget.swf"/>
then amend the widget config for your layers it should be pretty much self explainatry
Anthony
Many thanks. Is it possible send me source code of this widget to develope by flash builder?
Its the code in the link to the github page in my post above.
I download the source code and add it to my flex project but got this error. What does it mean?
1119: Access of possibly undefined property SUSPEND_TOC_HIDE_TIMER through a reference with static type class.
Regards,
Ha Thach
Ha Thach,
You get that error because the widget is not updated for ArcGIS Viewer for Flex 3.6
Thanks Robert. Yes, I'm using ArcGIS Viewer for Flex 3.6. When I comment out error message in TransparencyMenuItem.mxml and TocLayerMenu.mxml
where
//AppEvent.dispatch(AppEvent.SUSPEND_TOC_HIDE_TIMER, "true");
//AppEvent.dispatch(AppEvent.SUSPEND_TOC_HIDE_TIMER, null);
Now, the error message go away. This seem to solve the problem temporarily. Are you or the person who wrote this source code have any plan on update this TOCGroup widget?
I don't think the original developer is maintaining this widget any more but if you really want this widget updated then these are the changes to make.
TocLayerMenu.mxml
private function bordercontainer1_rollOverHandler(event:MouseEvent):void { AppEvent.dispatch(AppEvent.RESET_TOC_HIDE_TIMER, "true"); } private function bordercontainer1_rollOutHandler(event:MouseEvent):void { AppEvent.dispatch(AppEvent.START_TOC_HIDE_TIMER, null); }
protected function transparencyBorderContainer_rollOverHandler(event:MouseEvent):void { AppEvent.dispatch(AppEvent.RESET_TOC_HIDE_TIMER, "true"); } protected function transparencyBorderContainer_rollOutHandler(event:MouseEvent):void { AppEvent.dispatch(AppEvent.START_TOC_HIDE_TIMER, null); }
Robert, Thank you for your support. I'm really appreciated. This changes seem to work. I was able to compile the source code successfully. Have a wonderful afternoon.
Signed in members can post, follow updates, and more. New here? Register a free account.
