How to trigger mouse click to show popuprenderer
1420
07-21-2011 03:39 PM
TimLeigh
This is a duplicate post of http://forums.arcgis.com/threads/35200-How-to-trigger-mouse-click-to-show-popuprenderer as it was suggested  I post it in this forum.
I'm using the SFV and I'd like to show a popup of feature info when a user clicks on the results in the search widget. The standard results only take the basic attributes (primary display field), so I'd like to trigger a mouse click on the map to show the full popuprenderer based on the layer configuration in the map.
I've tried the following code, but the event doesn't seem to fire, any other suggestions?
var mouseEvent:MouseEvent = new MouseEvent(MouseEvent.MOUSE_UP, true, false, screenPt.x, screenPt.y );
var mapEvent:MapMouseEvent = new MapMouseEvent(MapMouseEvent.MAP_MOUSE_CLICK, map, showHighlightPoint);
mapEvent.relatedObject = MouseEvent as InteractiveObject;
map.dispatchEvent(mapEvent);
Tim
TylerWaring
Hi. Did you ever find a solution to this? I am trying to do something simelar to see if I can use something like this to popup and populate the editor.attributeInspector in the Editor Widget. I plan to use this to help validate attributes in the editor's attribute inspector. If the attributes do not pass the checks, I plan to just pop up the editor.attributeInspector again with a generated map click. Not sure if a generated map click event will do this though.
RhettZufelt
MVP Notable Contributor
Tim
So, what are you after here?  Since the popup in the search widget supports ALL the fields/attributes reported by REST, not sure what you are trying to do.
R_
