How to remove the restriction of 1000 features in results of the Query widget?
4533
03-22-2015 04:11 AM
Syed_AzamGhouri
How to remove the restriction of 1000 features in results of the Query widget? Thanks in advance.
Tags (1)
RobertScheitlin__GISP
Syed,
Services by default only return 1000 values, if you want to return more then you will need to up the limit in the service properties. See Maximum number of records returned by the server here:
http://resources.arcgis.com/en/help/main/10.2/index.html#/Setting_map_service_properties/0154000003p...
Syed,
