Google Street View Widget for the Flexviewer
15204
82
01-11-2011 02:25 AM
andrewj_ca
I wanted to get some feedback on my street view widget for the Flexviewer 2.*, Check it out here:
http://www.arcgis.com/home/item.html?id=f069d8a3aa304e29a432b48e5f64ca74
VenkatM
Did you copy my index.template.html?
requires lines:
<script src="http://maps.google.com/maps?file=api&amp;v=2.x&amp;key=ABQIAAAAkSuRQhsVGwtKfC10t-cYMhTBpCie6Uzwqy2E6AELFrU6ooWJHRTCzw4I8uhjHu7YLeP32UUD8WWq3Q" type="text/javascript"></script>
<script type="text/javascript" src="widgets  /StreetView/streetview.js"></script>
Check the casing of these lines
Hi Andrew,
Got it.. Awersome..!!!!.
Thank you so much for the help.
Regards.
-Venkat.
andrewj_ca
Great, be sure to rate the widget once you're up and running.
VenkatM
Definitely.. with my pleasure.
-Venkat.
VenkatM
Hi Andrew,
I have a question regarding Flexviewer2.2, I know it is not appropriate place to ask, just for the curiousity. Where can I find code related to the icon at bottom right corner i.e 'Powered by ESRI' icon?
Thanks in advance.
-Venkat.
andrewj_ca
Venkat,
The ESRI map object has a logoVisible property which you can set to false.
VenkatM
Venkat,
Thank you..
-Venkat.
andrewj_ca
Has anyone that has downloaded or used my code for the Street View Widget had any issues of late?  Starting this week, all my apps that use the street view code have stopped working or has intermittent problems.  Wondering if it's the api or something else that's going on here.
haThach
I recently has intermittent problems only within the street view when trying to use the go forward or backward arrow, which result in a grey window. But the initial startup, click on the street or drag the human icon to a different location seem to work fine. Any idea why? I'm currently using ie8 with flexviewer v2.3. Thanks!
JamesKo
Andrew,
I'm having the same problems as mentioned above. However, it does work in firefox and google chrome. One interesting note, if you try the code examples from google's own website on IE, you'll notice the same behaviour.
Regards,
James
GeorgiannaStrode
I can't compile Street View 2.4 with SFV 2.5.
The error is inside FrStreetView/WebForm.mxml at line 39 <flexiframe:IFrame .....
The error says:
"Could not resolve <flexiframe:IFrame> to a component implementation"
Any suggestions are greatly appreciated.
