Venkat,The ESRI map object has a logoVisible property which you can set to false.
Has anyone that has downloaded or used my code for the Street View Widget had any issues of late? Starting this week, all my apps that use the street view code have stopped working or has intermittent problems. Wondering if it's the api or something else that's going on here.
HI Andrew,Just tried your Street Widget ... on your webpage it looks great! I am fairly new at this Ia m usinf ArcGis viewer for Flex 3.0. I have copy and paste the compiled 3.0 to the widget added the widge string to the congif.xml and I am having a problem the widget is open, I click on the icon to start the street viewer and click on a street and nothing. I don't what is wrong...Can you please help ?GeraldGIS AnalystMoncton, NB
Gerald,This code isn't currently compiled for the 3.0 viewer. I have seen a few comments from other people have have successfully ported it over the the new 3.0 viewer. When I get an opportunity I will be updating the code, but for now I'd suggest looking at some of the other uploads from people. Sorry I've haven't been much help here.Andrew
Updated 3.0 API code found here. Install instructions to follow but I wanted to get the code out there.Cheers,Andrewhttp://www.arcgis.com/home/item.html?id=b721eec8dde442559e9c17acecd22188
GISProgrammer9,I've updated the size of the download. I also included a couple of readme files for those who are interested.Andrew
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en"> <head> <title>Web App</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta name="description" content="Esri ArcGIS viewer for Flex"/> <meta name="keywords" content="Esri, ArcGIS, Flex Viewer"/> <meta name="author" content="Esri"/> <!-- Include CSS to eliminate any default margins/padding and set the height of the html element and the body element to 100%, because Firefox, or any Gecko based browser, interprets percentage as the percentage of the height of its parent container, which has to be set explicitly. Fix for Firefox 3.6 focus border issues. Initially, don't display flashContent div so it won't show if JavaScript disabled. --> <style type="text/css" media="screen"> html, body { height:100%; } body { margin:0; padding:0; overflow:auto; text-align:center; background-color: #ffffff; } object:focus { outline:none; } #flashContent { display:none; } </style> <!-- Enable Browser History by replacing useBrowserHistory tokens with two hyphens --> <!-- BEGIN Browser History required section > <link rel="stylesheet" type="text/css" href="history/history.css" /> <script type="text/javascript" src="history/history.js"></script> <! END Browser History required section --> <script type="text/javascript"> var isIElt9 = false; </script> <!--[if lt IE 9]> <script type="text/javascript"> isIElt9 = true; </script> <![endif]--> <script src="http://maps.googleapis.com/maps/api/js?sensor=false" type="text/javascript"></script> <script type="text/javascript" src="widgets/StreetView/streetview.js"></script> <script type="text/javascript" src="swfobject.js"></script> <script type="text/javascript"> <!-- For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection. --> var swfVersionStr = "11.1.0"; <!-- To use express install, set to playerProductInstall.swf, otherwise the empty string. --> var xiSwfUrlStr = "playerProductInstall.swf"; var flashvars = {}; flashvars.localeChain = "en_US"; flashvars.resourceModuleURLs = "assets/locale/en_US.swf"; //flashvars.localeChain = "ar"; //flashvars.resourceModuleURLs = "assets/locale/ar.swf"; //flashvars.localeChain = "de_DE"; //flashvars.resourceModuleURLs = "assets/locale/de_DE.swf"; //flashvars.localeChain = "es_ES"; //flashvars.resourceModuleURLs = "assets/locale/es_ES.swf"; //flashvars.localeChain = "fr_FR"; //flashvars.resourceModuleURLs = "assets/locale/fr_FR.swf"; //flashvars.localeChain = "it_IT"; //flashvars.resourceModuleURLs = "assets/locale/it_IT.swf"; //flashvars.localeChain = "ja_JP"; //flashvars.resourceModuleURLs = "assets/locale/ja_JP.swf"; //flashvars.localeChain = "ko_KR"; //flashvars.resourceModuleURLs = "assets/locale/ko_KR.swf"; //flashvars.localeChain = "nb_NO"; //flashvars.resourceModuleURLs = "assets/locale/nb_NO.swf"; //flashvars.localeChain = "nl_NL"; //flashvars.resourceModuleURLs = "assets/locale/nl_NL.swf"; //flashvars.localeChain = "pl_PL"; //flashvars.resourceModuleURLs = "assets/locale/pl_PL.swf"; //flashvars.localeChain = "pt_BR"; //flashvars.resourceModuleURLs = "assets/locale/pt_BT.swf"; //flashvars.localeChain = "ro_RO"; //flashvars.resourceModuleURLs = "assets/locale/ro_RO.swf"; //flashvars.localeChain = "ru_RU"; //flashvars.resourceModuleURLs = "assets/locale/ru_RU.swf"; //flashvars.localeChain = "sv_SE"; //flashvars.resourceModuleURLs = "assets/locale/sv_SE.swf"; //flashvars.localeChain = "zh_CN"; //flashvars.resourceModuleURLs = "assets/locale/zh_CN.swf"; var params = {}; params.quality = "high"; params.bgcolor = "#ffffff"; params.allowscriptaccess = "sameDomain"; params.allowfullscreen = "true"; var isAIR = navigator.userAgent.indexOf("AdobeAIR") != -1; if (isAIR || isIElt9) { // workaround for overlaying tool tips and other content when loaded into an AIR app // workaround for cursor issue - https://bugs.adobe.com/jira/browse/SDK-26818 params.wmode = "opaque"; } var attributes = {}; attributes.id = "index"; attributes.name = "index"; attributes.align = "middle"; swfobject.embedSWF( "index.swf", "flashContent", "100%", "100%", swfVersionStr, xiSwfUrlStr, flashvars, params, attributes); <!-- JavaScript enabled so display the flashContent div in case it is not replaced with a swf object. --> swfobject.createCSS("#flashContent", "display:block;text-align:left;"); </script> </head> <body> <!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show when JavaScript is disabled. --> <div id="flashContent"> <p> To view this page ensure that Adobe Flash Player version 11.1.0 or greater is installed. </p> <script type="text/javascript"> var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://"); document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='" + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" ); </script> </div> <noscript> <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="100%" height="100%" id="index"> <param name="movie" value="index.swf" /> <param name="quality" value="high" /> <param name="bgcolor" value="#ffffff" /> <param name="allowScriptAccess" value="sameDomain" /> <param name="allowFullScreen" value="true" /> <!--[if !IE]>--> <object type="application/x-shockwave-flash" data="index.swf" width="100%" height="100%"> <param name="quality" value="high" /> <param name="bgcolor" value="#ffffff" /> <param name="allowScriptAccess" value="sameDomain" /> <param name="allowFullScreen" value="true" /> <!--<![endif]--> <!--[if gte IE 6]>--> <p> Either scripts and active content are not permitted to run or Adobe Flash Player version 11.1.0 or greater is not installed. </p> <!--<![endif]--> <a href="http://www.adobe.com/go/getflashplayer"> <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash Player" /> </a> <!--[if !IE]>--> </object> <!--<![endif]--> </object> </noscript> </body> </html>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en"> <head> <title>ArcGIS Viewer for Flex</title> <meta http-equiv="Content-Type" content="text/html; charset=utf-8" /> <meta name="description" content="Esri ArcGIS viewer for Flex"/> <meta name="keywords" content="Esri, ArcGIS, Flex Viewer"/> <meta name="author" content="Esri"/> <!-- Include CSS to eliminate any default margins/padding and set the height of the html element and the body element to 100%, because Firefox, or any Gecko based browser, interprets percentage as the percentage of the height of its parent container, which has to be set explicitly. Fix for Firefox 3.6 focus border issues. Initially, don't display flashContent div so it won't show if JavaScript disabled. --> <style type="text/css" media="screen"> html, body { height:100%; } body { margin:0; padding:0; overflow:auto; text-align:center; background-color: #ffffff; } object:focus { outline:none; } #flashContent { display:none; } </style> <!-- Enable Browser History by replacing useBrowserHistory tokens with two hyphens --> <!-- BEGIN Browser History required section > <link rel="stylesheet" type="text/css" href="history/history.css" /> <script type="text/javascript" src="history/history.js"></script> <! END Browser History required section --> <script type="text/javascript"> var isIElt9 = false; </script> <!--[if lt IE 9]> <script type="text/javascript"> isIElt9 = true; </script> <![endif]--> <script src="http://maps.googleapis.com/maps/api/js?sensor=false" type="text/javascript"></script> <script type="text/javascript" src="widgets/StreetView/streetview.js"></script> <script type="text/javascript"> var _gaq = _gaq || []; _gaq.push(['_setAccount', 'UA-26683112-1']); _gaq.push(['_trackPageview']); (function() { var ga = document.createElement('script'); ga.type = 'text/javascript'; ga.async = true; ga.src = ('https:' == document.location.protocol ? 'https://ssl' : 'http://www') + '.google-analytics.com/ga.js'; var s = document.getElementsByTagName('script')[0]; s.parentNode.insertBefore(ga, s); })(); </script> <script type="text/javascript" src="swfobject.js"></script> <script type="text/javascript"> <!-- For version detection, set to min. required Flash Player version, or 0 (or 0.0.0), for no version detection. --> var swfVersionStr = "11.1.0"; <!-- To use express install, set to playerProductInstall.swf, otherwise the empty string. --> var xiSwfUrlStr = "playerProductInstall.swf"; var flashvars = {}; var params = {}; params.quality = "high"; params.bgcolor = "#ffffff"; params.allowscriptaccess = "sameDomain"; params.allowfullscreen = "true"; var isAIR = navigator.userAgent.indexOf("AdobeAIR") != -1; if (isAIR || isIElt9) { // workaround for overlaying tool tips and other content when loaded into an AIR app // workaround for cursor issue - https://bugs.adobe.com/jira/browse/SDK-26818 params.wmode = "opaque"; } var attributes = {}; attributes.id = "agsview3"; attributes.name = "agsview3"; attributes.align = "middle"; swfobject.embedSWF( "index.swf", "flashContent", "100%", "100%", swfVersionStr, xiSwfUrlStr, flashvars, params, attributes); <!-- JavaScript enabled so display the flashContent div in case it is not replaced with a swf object. --> swfobject.createCSS("#flashContent", "display:block;text-align:left;"); </script> </head> <body> <!-- SWFObject's dynamic embed method replaces this alternative HTML content with Flash content when enough JavaScript and Flash plug-in support is available. The div is initially hidden so that it doesn't show when JavaScript is disabled. --> <div id="flashContent"> <p> To view this page ensure that Adobe Flash Player version 11.1.0 or greater is installed. </p> <script type="text/javascript"> var pageHost = ((document.location.protocol == "https:") ? "https://" : "http://"); document.write("<a href='http://www.adobe.com/go/getflashplayer'><img src='" + pageHost + "www.adobe.com/images/shared/download_buttons/get_flash_player.gif' alt='Get Adobe Flash player' /></a>" ); </script> </div> <noscript> <object id="agsview3" name="agsview3" classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" width="100%" height="100%" id="index"> <param name="movie" value="index.swf" /> <param name="quality" value="high" /> <param name="bgcolor" value="#ffffff" /> <param name="allowScriptAccess" value="sameDomain" /> <param name="allowFullScreen" value="true" /> <!--[if !IE]>--> <object type="application/x-shockwave-flash" data="index.swf" width="100%" height="100%"> <param name="quality" value="high" /> <param name="bgcolor" value="#ffffff" /> <param name="allowScriptAccess" value="sameDomain" /> <param name="allowFullScreen" value="true" /> <!--<![endif]--> <!--[if gte IE 6]>--> <p> Either scripts and active content are not permitted to run or Adobe Flash Player version 11.1.0 or greater is not installed. </p> <!--<![endif]--> <a href="http://www.adobe.com/go/getflashplayer"> <img src="http://www.adobe.com/images/shared/download_buttons/get_flash_player.gif" alt="Get Adobe Flash Player" /> </a> <!--[if !IE]>--> </object> <!--<![endif]--> </object> </noscript> </body></html>
See highlighted missing items in index.html. The html that you provided is not what I provided as part of the download.
Andrew, I copied the code from your post this morning and created a new index file. It's still not working for me. My Java savvy co-worker is on vacation this week so please bear with me. On line 104, is that a big grin or is it really "clsid:D27CDB6E..."? Any other thoughts?Tony
Tony I think you and I have the same issue. From Andrew's comment to me it sounds like you have the right assmumption for the clsid:. I've tried it both ways and still have the same issue....
