Cynthia,It was good speaking to you regarding this. I'm glad you are up and running.
Dira,Did you also include this line in the index.html file?<script type="text/javascript" src="widgets/Streetview/streetview.js"></script>That little line has all the Javascript functions for allowing Flex to speak with the Streetview API.Also,In the index.html file search for the word "theApp" in my file. This will also need to be in your file for the communication between the flash functions and the javascript functions. If you havn't done any customization to your html file I suggest overwriting it with what I supplied. Let me know if this helps, I'm always available to help.
I updated the casing issue, see if that fixes the problem.
Venkat,Are you using the compiled or uncompiled versions?
Did you copy my index.template.html? requires lines: <script src="http://maps.google.com/maps?file=api&v=2.x&key=ABQIAAAAkSuRQhsVGwtKfC10t-cYMhTBpCie6Uzwqy2E6AELFrU6ooWJHRTCzw4I8uhjHu7YLeP32UUD8WWq3Q" type="text/javascript"></script> <script type="text/javascript" src="widgets /StreetView/streetview.js"></script> Check the casing of these lines
