Format Numbers in Popup GUI in Viewer for Flex 3.3?
608
06-14-2013 11:35 AM
RichardHudson
Within ArcGIS Viewer for Flex 3.3, can one format numbers within the pop-up Configure GUI, under the Custom tab? For example, the value for "KEY_1" will appear "bold" if entered as follows:
Key Number: <b>{KEY_1}</b>
Specifically, I don't want commas appearing within certain numbers, and wish others to only display to two decimal places. If accomplished by editing the .xml file relating the pop-up for this feature, I believe the following statements would apply (although my map acts a little quirky when I put these statements in):
<field name="KEY_1" alias="Key Number:" visible="true"> <format usethousandsseparator="false"/> </field>
<field name="Shape.area" alias="Shape.area (sq.ft.): " visible="true"> <format precision="2"/> </field>
I would rather accomplish this within the GUI if it's possible.
Thank you, in advance, for any assistance.
RobertScheitlin__GISP
Richard,
   The GUI is not currently capable of assigning field formats.
Richard,
RichardHudson
Thank you very much, Robert, for the quick response. Take care!
