flex viewer errors(1046, 1067,1119) in the fresh install
3200
9
06-10-2013 07:13 AM
DeewendraShrestha
Hi there, I was hoping someone could help me figure out what I am missing. I am trying out my first install of flex viewer 3.3, with flex api 3.1. When I try to run my index.mxml file, I get bunch of error messages like :
1046: Type was not found or was not a compile-time constant: UniqueValueRenderer. RendererParser.as /arcgis-viewer-flex/src/com/esri/viewer/utils line 74 Flex Problem
1046: Type was not found or was not a compile-time constant: VETiledLayer. ConfigManager.as /arcgis-viewer-flex/src/com/esri/viewer/managers line 1201 Flex Problem
1119: Access of possibly undefined property exportColumnDelimiter through a reference with static type com.esri.ags.components:AttributeTable. AttributeTableWidget.mxml /arcgis-viewer-flex/src/widgets/AttributeTable line 933 Flex Problem
1120: Access of undefined property CalendarField. AttributeTableWidget.mxml /arcgis-viewer-flex/src/widgets/AttributeTable line 883 Flex Problem
etc
It sounds like I am missing some library files. Strange thing is I had the file running with flex api 3.3 but our client uses api 3.1 so I changed the flex api, but now when I revert back to flex api 3.3 I still get these errors. If you could provide me any suggestions as to how to resolve these issues, I would appreciate it a lot.
Regards,
Deewen
GISDev1
Yup, I am using SDK 4.6.0.
Wait, why did you use 3.1 API with 3.2 Viewer?
The Viewer and API version need to match.
GISDev1
etc
Regards,
Deewen
Did you try a Clean in Flash Builder?
DeewendraShrestha
Yes I tried the clean build, but it didn't help. I must say I am bit scared to use clean build - I have had this happen to me multiple times where after I do a clean build, it says the index.html file is missing in the build path, its probably due to some error that the files were not getting compiled though!
GISDev1
Have you done a lot of customizations yet? It would probably be easiest to just create a new Project.
DeewendraShrestha
No I have not done any customization, I just wanted the fresh install to work. I am going to give flex 3.2 a try, maybe that will work for me. I'll let you know how it goes. Thanks.
DeewendraShrestha
Same story with flex viewer 3.2. I got fewer errors(58 as opposed to 72), and it ends with launch failed alert box saying "file not found:/D:/.../bin-debug/index.html"
I did Build and then run the project but same issue!
These are the steps that I followed:
1) downloaded arcgis-viewer-flex-3.2-src.zip(uncompiled source code) file
2) loaded that up in FB 4.6
3) added agslib-3.1-2012-12-12.swc in my lib folder
4) ran the index.mxml file(tried build too)
This is the subset of errors I get:
1046: Type was not found or was not a compile-time constant: UniqueValueRenderer. RendererParser.as /FlexViewer3.2/src/com/esri/viewer/utils line 74 Flex Problem
1046: Type was not found or was not a compile-time constant: VETiledLayer. ConfigManager.as /FlexViewer3.2/src/com/esri/viewer/managers line 1201 Flex Problem
1046: Type was not found or was not a compile-time constant: VETiledLayer. OverviewMapComponent.mxml /FlexViewer3.2/src/widgets/OverviewMap line 273 Flex Problem
1119: Access of possibly undefined property showInLegend through a reference with static type com.esri.ags.layers:ArcGISDynamicMapServiceLayer. ConfigManager.as /FlexViewer3.2/src/com/esri/viewer/managers line 1054 Flex Problem
1119: Access of possibly undefined property showInLegend through a reference with static type com.esri.ags.layers:ArcGISDynamicMapServiceLayer. ConfigManager.as /FlexViewer3.2/src/com/esri/viewer/managers line 1057 Flex Problem
1120: Access of undefined property VETiledLayer. ConfigManager.as /FlexViewer3.2/src/com/esri/viewer/managers line 1199 Flex Problem
1180: Call to a possibly undefined method UniqueValueRenderer. RendererParser.as /FlexViewer3.2/src/com/esri/viewer/utils line 74 Flex Problem
GISDev1
Are you using Flex SDK 4.6?
Project-Properties-Flex Compiler
DeewendraShrestha
GISDev1
DeewendraShrestha
Ohh thanks a ton, I had no clew that I had to match the versions. Thank you so much for helping me out with my noob issue. I got the viewer working now.
Regards,
Deewen
