if (editGraphic.geometry is Polyline || editGraphic.geometry is Polygon || editGraphic.geometry is Extent)
<Layer queryable="0" opaque="0" cascaded="0"> <Name>hypsography</Name> <Title>Hypsography</Title> - <Abstract> The Hypsography layer represents elevation points and continuous lines formed by peaks of equal altitude used to describe the topography. Elevation of points and lines is always calculated from mean sea level. </Abstract> <SRS>EPSG:4269</SRS>
SecurityError: Error #2048: Security sandbox violation: http://465793h/FlexViewer2.2/index.swf cannot load data from http://wms.ess-ws.nrcan.gc.ca/wms/toporama_en?VERSION=1.3.0&REQUEST=GetCapabilities&SERVICE=WMS. at Function/com.esri.ags.layers:WMSLayer/private:loadCapabilities/com.esri.ags.layers:myFaultFunction() at mx.rpc::AsyncResponder/fault() at mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyFault() at mx.rpc.events::FaultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders() at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent() at HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent() at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::faultHandler() at mx.rpc::Responder/fault() at mx.rpc::AsyncRequest/fault() at DirectHTTPMessageResponder/securityErrorHandler() at flash.events::EventDispatcher/dispatchEventFunction() at flash.events::EventDispatcher/dispatchEvent() at flash.net::URLLoader/redirectEvent()
Hi dpaddock,I made the change in config.xml on basemaps:<layerlabel="axa"type="wms"visible="true"visiblelayers="0,2"wkid="EPSG:31600"url="http://localhost:8080/geoserver/wms"/>and i received a blank page..ESRI logo si loaded and staying on Transferring data from localhost..i have a crossdomain.xml if help.
The wkid goes on the map tag, but it may not be needed. Make sure the visiblelayers match the available layer names. You may need to use a tool like HttpFox to see what the request/responses are.
Cynthia (and others), to migrate your 2.1 viewers:A) If working with the compiled version:Download the new viewer.Copy your modified xml's file over to the new viewer.Review What's new to see if there's something new you want to take advantage of. If working with the source code:Download the new viewer.Copy your modified xml's file over to the new viewer.Review What's new to see if there's something new you want to take advantage of.For changes made in the mxml files ... depends. If it was something that was fixed, then do nothing. For fixes that you want to migrate over, the best way is probably to compare that specific mxml and integrate your changes with ours.
Brian,We'll look at supporting wkid on the layer tag for type "wms" in a future release.As a work-around, you can try this:<layer label="NOAA Infrared Satellite" type="wms" visible="false" visiblelayers="RAS_GOES_I4" url="http://nowcoast.noaa.gov/wms/com.esri.wms.Esrimap/obs?srs=EPSG:102113"/>This seems to work but is service dependent. Any additional url parameters are sent by the API in its requests to the servcie. The API will overwrite any it uses, but since it's case-sensitive and it uses SRS, then both srs and SRS will be sent and in this instance, the service seems to look for the srs parameter first.
The overviewMapWidget doesn't work in this new release because it only displays a blank window
Cynthia (and others), to migrate your 2.1 viewers: If working with the source code:Download the new viewer.Copy your modified xml's file over to the new viewer.Review What's new to see if there's something new you want to take advantage of.For changes made in the mxml files ... depends. If it was something that was fixed, then do nothing. For fixes that you want to migrate over, the best way is probably to compare that specific mxml and integrate your changes with ours.
Signed in members can post, follow updates, and more. New here? Register a free account.
