Filling Combobox from database
1291
06-05-2014 03:37 PM
SaadiaElaarji
Hello,
I'm using flex, Java and sql server for webmapping application and i'm trying to fill my combobox from database, this is the code, i think all is right but it doesn't work !!! can you help be to find what i'm messing !!
so first this is the code of my class, it selects a column (Intitule Chapitre) from database
public class RapportDao {
    public Connection conectar(){
        Connection cn = null;
        String connectionUrl = "jdbc:sqlserver://localhost\\SQLEXPRESS;databaseName=mabase;user=sa;password=sa;";
        try
            Class.forName("com.microsoft.sqlserver.jdbc.SQLServerDriver");
            cn = DriverManager.getConnection(connectionUrl);
        catch(Exception ex)
            System.out.println("Error : " + ex.getMessage());
        return cn;
public ArrayList<Rapport> Selection() {
             Connection conn = conectar();
             ArrayList<Rapport> list = null;
             if (conn!=null){
                 try{
                     Rapport pr = null;
                     String a;
                     list = new ArrayList<Rapport>();
                     String sql = "select IntituleChap from Rapport";
                     Statement st = conn.createStatement();
                     ResultSet rs=st.executeQuery(sql);
                     while (rs.next())
                         a=rs.getString("IntituleChap");
                         pr  = new Rapport();
                         pr.setIntituleChap(a);
                         list.add(pr);
                 catch(SQLException e ) {
                     // System.out.print(e.getMessage());
                     System.out.println("Error = " + e.getMessage());
             }else
             return list;
and this is my actionscript code for combobox
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
           xmlns:s="library://ns.adobe.com/flex/spark"
           xmlns:mx="library://ns.adobe.com/flex/mx"
           xmlns:esri="http://www.esri.com/2008/ags"
           minWidth="1000" minHeight="700" applicationComplete="application1_applicationCompleteHandler(event)">
<fx:Script>
            <![CDATA[
    import spark.components.ComboBox;
    private function getTypeprojetResult(event : ResultEvent):void
                    //Alert.show(""+event.result);
 protected function application1_applicationCompleteHandler(event:FlexEvent):void
    RemoteRapportDao.Selection()
    <fx:Declarations>
            <s:RemoteObject id="RemoteRapportDao"
                            destination="RapportDaoDest"
                            fault="onFault(event)">
                <s:method name="Selection" result="getTypeprojetResult(event);"/>
            </s:RemoteObject>
        </fx:Declarations>
<s:ComboBox id="cmb" x="10" y="13" width="162" labelField="IntituleChap" dataProvider="{RemoteRapportDao.Selection.lastResult}" />
RemoteRapportDao : is the id RemoteObject
Selection() : my method on the service
but at last i get this instead of labelfields
[ATTACH=CONFIG]34401[/ATTACH]
any one could help me ?
raffia
I remember getting this "object"object" output when trying to do the same thing, I got around it by converting the values using toString() function. Did you try that?
SaadiaElaarji
Thank you raffialexanian for replying,
But where should i add it ?!!  can you give me an example ?!!
