Exclude layers from Printing Service legend
3078
5
11-05-2012 04:30 AM
RoseZhou
Is it possible to exclude some layers from the legend of the Printing service just like the Legend Widget?
Right now I excluded two layers from the Legend Widget, but when print the map, the legend of these two layers are shown on the printed map. This is not consistent.
Rose
RoseZhou
I have figured it out by custimizing the source code of ExportWebMapForm.mxml.
Cheers
Rose
RoseZhou
Cheers
Rose
JasonNielsen
Would you mind sharing where you changed the code at to accomplish this? I thought i had to do this thru the JSON for the print service but if you can only change it in the .MXML that would be a lot easier.
Thank you.
RoseZhou
Thank you.
Check function getLegendOptions() in ExportWebMapForm.mxml, it excluded BaseMapLayer by default. You can customize this function to exlcude other layers.
Hope this helps.
Rose
JasonNielsen
Hope this helps.
Rose
Could you show a bit on how you excluded a layer out of an operational service?  Maybe if i can see how to exclude one layer i can figure out the rest of it out.
thanks
BjornSvensson
FYI - "Layers can be excluded from legend when printing" will be part of the next release: version 3.1 (planned for December).
