eSearch & Identify Popup Link Image-Very large
1163
7
02-28-2014 04:47 AM
EricVenden
Good morning,
An issue was recently pointed out to me by one of our users.  The image that is used as the popup link (as well as at the bottom of eSearch or Identify results dialogs) is very large (see attached image).  I am not sure when exactly this happened..I don't believe it was present at 3.6, but may have occurred since???..I am going to do some digging to see.
The image in the search results is displayed properly, but the image in the popup is rather large.
This occurs on both the eSearch and Identify popups - not in the results dialog.
Here is an example of the links tag in the config xml:
   <links>
    <link alias="Tax Maps">
    <![CDATA[http://maps.lakecountyil.gov/taxmapgallery/TaxMap.html?PINAddress={ims_sde.DBO.tax_parcels.PIN}]]>
    <icon><![CDATA[assets/images/map.png]]></icon>
    </link>
   </links>
Anyone encountered this?
Eric V
Gurnee, IL
RobertScheitlin__GISP
Eric,
   The eSearch has now been updated to support configuration of this as well.
EricVenden
Just an update on this issue:
I looked at the Identify widget and found that 3.6 & 3.6.1 still displayed text links in the popup and not the images.  This is how I had intended.
Starting at 3.6.2, the Identify widget popup displays the image instead of the text.  The images are still displayed in the results windows.
I have not looked at the eSearch widget.
Also, I have NOT changed my xml file between 3.6 widget updates.
Eric
EricVenden
Additional update - I do now see that starting in 3.6.2,
"Links with icon specified and link url is not an image will appear as a image (using the link icon) in the popup that is hyperlinked to the specified link url"    per the documentation.
Is this an either or now?  Only display text or only an icon for the link?
Eric,
   No this new feature is not configurable. It sounds like I do need to look at that though.
EricVenden
Thank you Robert
Eric,
   I have updated the Identify Widget to give the ability to configure the popuplinktype="text" the default is popuplinktype="image" (the way that popups act currently). I will probably have the eSearch done 3/3/2014 to add this same attribute to the link tag.
Eric,
EricVenden
Thanks much Robert
