Error due to less than or equal (<= symbol) in query
2676
12
03-06-2013 12:17 PM
PierreLarondelle
Hello,
I've tried the following query in Flash Builder 4.6 : <esri:Query id="query1FR" where = " pw_fre <= '{qText2FR.text}' "  which causes an error while compiling with a warning message telling that the value of atribute "where" associated to an element type "esri:query" must not contain the character '<'
How do I query properly in Flex using operators "<" and "<=" , can anybody show me how to do it the right way ?
Thanks already,
Pierre
AnthonyGiles
Honored Contributor
Pierre,
You may better off setting your where clause and the expression in the actionscript instead of the mxml. Have a look at ths older post from Robert where he help someone else out with querying dates:
http://forums.esri.com/Thread.asp?c=158&f=2421&t=278917
Regards
Anthony
AnthonyGiles
Honored Contributor
Pierre,
If you want to use < or > than you need to use:
&lt; or &gt;
Other wise the xml thinks you are closing or creating another tag
Regards
Anthony
AnthonyGiles
Honored Contributor
Pierre,
Ignore my post above that relates to using the greater than and less than symbols in an xml config. You should be able to use the <=, your problem maybe that you are trying to do a less than or equal to against a text input.
Regards
Anthony
PierreLarondelle
Anthony, thanks for the quick reply but I don't use an external XML config. The faulting query code is written in a Flash Builder mxml module within the <fx : Declarations> tag.
Pierre
AnthonyGiles
Honored Contributor
Pierre,
I'm not in front of a system to check but try something like:
pw_fre <= {Number(qText2FR.text)}
Regards
Anthony
PierreLarondelle
Anthony, the TextInput catch a date (dd/mm/yyyy) as value for querying. What I try to do is to retrieve all dates that are <= than the date entered in the TextInput.
Pierre
RobertScheitlin__GISP
Pierre & Anthony,
   mxml is still xml and you still need to escape the < and >
PierreLarondelle
Ok Anthony, I will try your code and will let you know what happened.
Thanks.
Pierre
PierreLarondelle
Thanks for your reply too Robert, I will modify with both your advices.
Pierre
AnthonyGiles
Honored Contributor
Pierre,
Regards
Anthony
