Enhanced-Search-Widget-for-FlexViewer Part III
206200
776
04-30-2013 03:58 PM
RobertScheitlin__GISP
All,
   Here is a new thread to post questions and discuss the Enhanched Search Widget. The old thread was getting too long.
Nick,
   Thanks for the feedback. For the short term fix. make sure that you maximize your App Builder window first, then configure the widget.
TonyAlmeida
MVP Regular Contributor
I have download and update the Enhanced Search widget version from 3.7 to 3.7.1 for FlexViewer 3.7 now when i click on the binoculars ArcGIS Viewer for flex just turns white. Is there a bug on the 3.7.1? I also could not get the search results window on the bottom of Enhanced Search widget version from 3.7, anything thoughts on why i wasn't getting the search results window?
Thanks.
Tony,
   Version 3.7 had a bug that prevented the fixed and floating datagrid from displaying results.
Version 3.7.1 fixed this issue. When you updated from 3.7 to 3.7.1 did you replace both the eSearchWidget.swf and the SearchWidgetFixedDG.swf?
TonyAlmeida
Robert thanks for the super fast reply and VERY helpful widget!
I am newbee to flex, i figured i would start off easy and start with just the ArcGIS viewer for Flex Application Builder.
I basically just download the Enhanced Search Widget from here link and click on
Code Attachment  eSearch.zip and download it, then added the widget through Flex Applicaiton Builder, so to answer your question no i have not replaced both .swf files. I am not sure on how to replace these files, where are the files and how and where do i  replace them?
Tony,
  OK that changes things a lot. In Application builder there is now way to add the Fixed Datagrid using the App Builder GUI. To do that you have to add it manually to the config.xml
  So you would look in your flexviewers directory (i.e. C:\inetpub\wwwroot\flexviewers\eSearchGUITest\config.xml) and add this line above the widgetcontainer line.
<widget left="0" right="0" bottom="0" url="widgets/eSearch/SearchWidgetFixedDG.swf" config="widgets/eSearch/SearchWidgetFixedDG.xml"/>
My previous instructions were for non-Appbuilder users. So the next question is how did you upgrade your App Builder to use the 3.7.1 eSearch widget?  You should have gone into the Manage Custom Widgets and deleted the 3.7 version and then added the 3.7.1 and then in your app that uses the eSearch you should have done the same (removed and added back the newer version).
TonyAlmeida
I added the line you said to add to the C:\inetpub\wwwroot\flexviewers\New2\config.xml but now once i start the Arcgis Viewer for flex app and click on view the pages just goes blank.
Here is what i edited.
<?xml version="1.0" ?>
<configuration>
    <title>ArcGIS Viewer for Flex</title>
    <logo>assets/images/logo.png</logo>
    <style>
        <colors>0xffffff,0x333333,0x101010,0x0,0xffd700</colors>
        <alpha>0.8</alpha>
        <font name="Verdana"/>
        <titlefont name="Verdana"/>
        <subtitlefont name="Verdana"/>
    </style>
    <!-- replace the following url with your own geometryservice -->
    <geometryservice url="https://utility.arcgisonline.com/arcgis/rest/services/Geometry/GeometryServer"/>
    <widget url="widgets/Navigation/NavigationWidget.swf" config="widgets/Navigation/NavigationWidget.xml" left="10" top="50"/>
    <widget url="widgets/OverviewMap/OverviewMapWidget.swf" config="widgets/OverviewMap/OverviewMapWidget.xml" right="0" bottom="0"/>
    <widget url="widgets/MapSwitcher/MapSwitcherWidget.swf" config="widgets/MapSwitcher/MapSwitcherWidget.xml" right="20" top="55"/>
    <widget url="widgets/HeaderController/HeaderControllerWidget.swf" config="widgets/HeaderController/HeaderControllerWidget.xml" left="0" top="0"/>
    <map attributionvisible="true" esrilogovisible="true" openhandcursorvisible="false" scalebarvisible="true" scalebar="default" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" initialextent="-13080415.120714309 5354549.420385569 -12913018.028769707 5448719.839232944" wkid="102100" top="40" portalurl="https://www.arcgis.com/">
        <basemaps>
            <layer type="tiled" label="Streets" copyright="" icon="https://www.arcgis.com/sharing/rest/content/items/d8855ee4d3d74413babfb0f41203b168/info/thumbnail/wo..." url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" visible="true"/>
        </basemaps>
        <operationallayers>
            <layer type="feature" label="Tax Parcels" copyright="" url="http://XXXX/arcgis/rest/services/XX/XX/MapServer/0" popupconfig="popups/PopUp_1.xml" mode="onDemand" visible="true"/>
        </operationallayers>
    </map>
    <widgetcontainer layout="float">
        <widget url="widgets/Draw/DrawWidget.swf" config="widgets/Draw/DrawWidget.xml" label="Draw" icon="assets/images/i_draw2.png"/>
        <widget url="widgets/Print/PrintWidget.swf" config="widgets/Print/PrintWidget.xml" label="Print" icon="assets/images/i_print.png"/>
        <widget url="widgets/eSearch/eSearchWidget.swf" config="widgets/eSearch/eSearchWidget_1.xml" label="Enhanced Search Widget" icon="assets/images/i_search.png"/>
    </widgetcontainer>
</configuration>
aI added the 3.7.1 eSearch widget through Arcgis Viewer for Flex's manage custom widgets. actually now that i think about it i believe i clicked on add and selected teh 3.7.1 eSearch widget and a popup asked me if i wanted to replace the 3.7 one.
I have not just deleted the widget in custom widget manager in Arcgis Viewer for flex and re-added the new 3.7.1 and after adding the widget to my map. Once i click on preview the map still goes blank, I tried re-adding the 3.7 and the screen still goes blank...weird.
Tony,
   I see the issue. I will get it fixed asap and deploy another release.
TonyAlmeida
Robert,
Sounds good please let me know when its ready for download. I gratefully appreciate all your efforts.
Tony,
   OK try 3.7.2, now available.
TonyAlmeida
I viewed the 3.7.2 application and i noticed that the search results table was not populating after i did a search on the Calhoun Parcels, on previous releases they were populated after a search. I tried multiple searches and the search results were not populating.
Would this affect the code attachment eSearch.zip on this page?
Tony
