/* * Function That takes all the graphics in a defined GraphicsLayer and adds unions them into one geometry * @param GraphicsLayer gl is the graphics layer to union * @return Geometry of the unioned graphics */ private function unionGeoms2(gl:GraphicsLayer):Geometry { var retGeom:Geometry; var mPoint:Multipoint = new Multipoint(null); mPoint.spatialReference = map.spatialReference; var mPoly:Polygon = new Polygon(null); mPoly.spatialReference = map.spatialReference; var mPolyL:Polyline = new Polyline(null); mPolyL.spatialReference = map.spatialReference; var rType:String; //globals var poly:Polygon; var ext:Extent; var i:int; var j:int; var mp:MapPoint; var ringArray:Array; for each (var graphic:Graphic in gl.graphicProvider){ if(graphic.geometry.type == "esriGeometryPoint" && !addTolerance.selected){ mPoint.addPoint(graphic.geometry as MapPoint); rType = "point"; }else if (graphic.geometry.type == "esriGeometryPoint" && addTolerance.selected){ ext = createExtentAroundMapPoint(graphic.geometry as MapPoint, pointSearchTolerance) as Extent; poly = ext.toPolygon(); for (i = poly.rings.length - 1; i >= 0; i--){ ringArray = []; for (j = 0; j < poly.rings.length; j++){ mp = poly.getPoint(i,j) as MapPoint; mp.spatialReference = poly.spatialReference; ringArray.push(mp); } mPoly.addRing(ringArray); } rType = "poly"; mPoly.spatialReference = poly.spatialReference; } if(graphic.geometry.type == "esriGeometryMultipoint"){ var mp1:Multipoint = graphic.geometry as Multipoint var pnts:MapPoint; for (var p:int=0;p < mp1.points.length; p++){ mPoint.addPoint(mp1.points ); } rType = "point"; } if(graphic.geometry.type == "esriGeometryPolygon"){ poly = graphic.geometry as Polygon; for (i = poly.rings.length - 1; i >= 0; i--){ ringArray = []; for (j = 0; j < poly.rings.length; j++){ mp = poly.getPoint(i,j) as MapPoint; mp.spatialReference = poly.spatialReference; ringArray.push(mp); } mPoly.addRing(ringArray); } rType = "poly"; mPoly.spatialReference = poly.spatialReference; } if(graphic.geometry.type == "esriGeometryPolyline"){ var polyl:Polyline = graphic.geometry as Polyline; for(var l:int=polyl.paths.length-1; l >= 0; l--){ var pathArray:Array = []; for (j = 0; j < polyl.paths.length; j++){ mp = polyl.getPoint(l,j) as MapPoint; mp.spatialReference = polyl.spatialReference; pathArray.push(mp); } mPolyL.addPath(pathArray); } rType = "line"; } if(graphic.geometry.type == "esriGeometryEnvelope"){ ext = graphic.geometry as Extent; poly = ext.toPolygon(); for (i = poly.rings.length - 1; i >= 0; i--){ ringArray = []; for (j = 0; j < poly.rings.length; j++){ mp = poly.getPoint(i,j) as MapPoint; mp.spatialReference = poly.spatialReference; ringArray.push(mp); } mPoly.addRing(ringArray); } rType = "poly"; mPoly.spatialReference = poly.spatialReference; } } switch(rType){ case "point":{ retGeom = mPoint; break; } case "poly":{ retGeom = mPoly; break; } case "line":{ retGeom = mPolyL; break; } } return retGeom; }
Robert,I tried your 3.3.3, but the pulldown is still not populating. I was able to extract the ArcGIS Server logs for the process in question on both servers. First, here is the one that works:<Msg time='2013-06-10T13:36:31' type='INFO3' code='4006' target='hs_wm.MapServer' machine='xyz' user='UNET\brophyt' thread='7440' elapsed='0.03100'>Server Context created.</Msg> <Msg time='2013-06-10T13:36:31' type='INFO2' code='100001' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='xyz' user='UNET\brophyt' process='8364' thread='2536'>String request received. Request size is 173151 characters.</Msg> <Msg time='2013-06-10T13:36:31' type='INFO2' code='10106' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='xyz' user='UNET\brophyt' process='8364' thread='2536'>QueryData has started.</Msg> <Msg time='2013-06-10T13:36:36' type='INFO3' code='10107' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='xyz' user='UNET\brophyt' process='8364' thread='2536' elapsed='4.38601'>QueryData has completed.</Msg> <Msg time='2013-06-10T13:36:36' type='INFO2' code='100002' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='xyz' user='UNET\brophyt' process='8364' thread='2536' elapsed='4.39902'>String request succesfully processed. Response size is 45108 characters.</Msg> <Msg time='2013-06-10T13:36:36' type='INFO3' code='4007' target='hs_wm.MapServer' machine='xyz' user='UNET\brophyt' thread='4220' elapsed='4.43000'>Server Context released.</Msg>Here is the one that fails to populate. <Msg time='2013-06-10T13:36:31' type='INFO3' code='4006' target='hs_wm.MapServer' machine='yyyyyy' user='?' thread='120460' elapsed='0.01600'>Server Context created.</Msg> <Msg time='2013-06-10T13:36:31' type='INFO2' code='100001' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='yyyyyy' user='?' process='121360' thread='121304'>String request received. Request size is 173151 characters.</Msg> <Msg time='2013-06-10T13:36:31' type='INFO2' code='10106' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='yyyyyy' user='?' process='121360' thread='121304'>QueryData has started.</Msg> <Msg time='2013-06-10T13:36:31' type='ERROR' code='10837' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='yyyyyy' user='?' process='121360' thread='121304'>Geodatabase error: Logfile not found.</Msg> <Msg time='2013-06-10T13:36:31' type='ERROR' code='10837' target='hs_wm.MapServer' methodName='MapServer.QueryFeatureData' machine='yyyyyy' user='?' process='121360' thread='121304'>Genaral GeoDatabase Error.</Msg> <Msg time='2013-06-10T13:36:36' type='INFO3' code='10107' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='yyyyyy' user='?' process='121360' thread='121304' elapsed='0.22043'>QueryData has completed.</Msg> <Msg time='2013-06-10T13:36:31' type='ERROR' code='100005' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='yyyyyy' user='?' process='121360' thread='121304' elapsed='0.23043'>Method failed.HRESULT = 0x80041530 : This is a FACILITY_ITF error that is specific to the interface that returned the error. See documentation of the interface that returned this error for information about this HRESULT.</Msg> <Msg time='2013-06-10T13:36:36' type='DEBUG' code='100000' target='hs_wm.MapServer' methodName='MapServer.QueryData' machine='yyyyyy' user='?' process='121360' thread='121304'>ERROR INFO = Error processing server request.</Msg> <Msg time='2013-06-10T13:36:36' type='INFO3' code='4007' target='hs_wm.MapServer' machine='yyyyyy' user='?' thread='118788' elapsed='0.28000'>Server Context released.</Msg> Do you know what, "Geodatabase error: Logfile not found." on line 4 is about? Do you know where this log file is located? Could this be a permissions issue? I am running out of ideas.//I almost forgot. The first set of logs are from our UNCLAS server, querying hs_wm mapservice who's data resides in ArcSDE on another ORACLE box - it works fine.The second set of logs are from our CLASS server, querying the same hs_wm mapservice who's data resides in ArcSDE on another ORACLE box - it does not work. The interesting thing I found out through testing --> If I export the data being queried into a FGB local to ArcGIS Server - The dropdown works fine.//Thanks for your help.
Matt, The XML does not like when you use the greater than or less than symbol in your XML as those mean something to the XML parser. You need to esacape the Less Than with < and Greater Than with >
Henry:Can you add a new field to your layer's datasource that has this information already concatenated so you can use Robert's eSearch widget with one field so it is not so awkward for the enduser?
Robert,Is it possible to include a caption or title for each link? I have 4 photos looking each way at rail crossings that display fine, but I would like each of them to be labeled (see attachment below). I've gone over the documentation and I'm not seeing anything that will facilitate this. Am I missing something?Code (snippet of the links area): <field name="PicForwardLink" alias="Pic Forward" visible="false"/> <field name="PicRightLink" alias="Pic Right" visible="false"/> <field name="PicBackLink" alias="Pic Back" visible="false"/> <field name="PicLeftLink" alias="Pic Left" visible="false"/> </fields> <links> <link alias="FRA Rail Crossing Site" disablelinksifnull="false" disableinpopups="false"> <![CDATA[http://safetydata.fra.dot.gov/OfficeofSafety/PublicSite/Crossing/Crossing.aspx]]> <icon><![CDATA[assets/images/FRA.png]]></icon> </link> <link alias="Looking Forward" includeinresults="true" field="PicForwardLink" disablelinksifnull="true" disableinpopups="false" > <![CDATA[{PicForwardLink}]]> <icon><![CDATA[assets/images/w_link_U.png]]></icon> </link> <link alias="Looking Right" includeinresults="true" field="PicRightLink" disablelinksifnull="true" disableinpopups="false" > <![CDATA[{PicRightLink}]]> <icon><![CDATA[assets/images/w_link_R.png]]></icon> </link> <link alias="Looking Back" includeinresults="true" field="PicBackLink" disablelinksifnull="true" disableinpopups="false" > <![CDATA[{PicBackLink}]]> <icon><![CDATA[assets/images/w_link_D.png]]></icon> </link> <link alias="Looking Left" includeinresults="true" field="PicLeftLink" disablelinksifnull="true" disableinpopups="false" > <![CDATA[{PicLeftLink}]]> <icon><![CDATA[assets/images/w_link_L.png]]></icon> </link> </links> [ATTACH=CONFIG]25305[/ATTACH]Thanks for all your great code......
Michael, There is currently nothing in place for what you are after. I will add this to the enhancement request list.
Dave, Can you zoom your map out to the world extent and see if the graphics are in the arm-pit of Africa (i.e.at 0,0)? If so can you share your eSearchWidget.xml and let me know the WKID of your data.
Dave,So are you using esri basemaps or are you only using your own data (including basemaps)?Did you find your graphics at 0,0?Is your data a joined to a database view?
