Enhanced-Search-Widget-for-FlexViewer Part II
162359
552
04-19-2012 08:03 AM
RobertScheitlin__GISP
All,
   I am pleased to announce the next release of my eSearch Widget.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
Version 2.5.1.7 - 4/19/2012
* Added ability to search (flat/standalone/no geometry) tables.
* This time all Zooming uses the same scaling (popup, datagrid, widget results, zoom to all).
* Added Relates icon/button to datagrids so that you can click on it in the datagrid to
  open relates choice dialog.
* Move all skins to a skins package for cleaner organization.
* Links that are not associated with a field now work.
* Ability to disable the relates tab in the fixed widget is now configurable.
PeterHoffman
There is a setting in ArcGIS server that usually limits returned records to 500 or 1000, you can check this. Also I would make sure the field in question is indexed.
There is a new thread for this subject.
Enhanced-Search-Widget-for-FlexViewer Part III | GeoNet
Cheryl,
   Peter has some good points there. I sounds like you may have already adjusted the servers max records property if you are getting near 3000 though. This thread was closed in the old forums in favor of the new thread Peter has linked. Some how in the move to GeoNet this thread was reopened.
If you can post your eSearchWidget.xml in this link Enhanced-Search-Widget-for-FlexViewer Part III‌ I can look at the issue.
Timothy Hales‌ is it possible to close a thread to future comments as it was in the old forums? I had gotten Jim to close this thread due to size.
TimothyHales
Esri Notable Contributor
Robert, I have re-closed this discussion.
