<expression alias="NAME" textsearchlabel="Search by Street Name:">[INDENT]<values><value prompt="Example: Centre St S" isvaluerequired="true" uniquevalsfromfield="NAME">NAME = '[value]'</value> </values> [/INDENT] </expression>
So what is it do or not doing? Do you get the gathering unique values indicator with the count message?
<widget left="0" right="0" bottom="0" url="widgets/eSearch/SearchWidgetFixedDG.swf" config="widgets/eSearch/SearchWidgetFixedDG.xml"/>
<widget label="Search" left="600" top="50" height="450" preload="open" icon="assets/images/i_search.png" config="widgets/eSearch/eSearchWidget.xml" url="widgets/eSearch/eSearchWidget.swf"/>
Slade, In your widget results do you see the binoculars? Like this?[ATTACH=CONFIG]20626[/ATTACH]
<symbology> <picturemarkersymbol url="assets/images/i_search.png" height="30" width="30" xoffset="0" yoffset="0" /> </symbology>
Hi Robert,When using the Graphical Search (I noticed this in your linked site - http://gis.calhouncounty.org/FlexViewer3.1/index.html?config=config-eSearch.xml&esearch=2&slayer=3&exprnum=1 for Road Centerlines, as well as my own testing), after the Results are shown, if you try to click on the map then it will draw another shape instead of allowing the user to click on one of the highlighted search results on the map. Not sure if it's just a config issue?Dan
Dan, As Rhett suggested your fist issue is a configuration issue. Thanks for reporting the 1009 error.
