When you click Query Related Records you will need to have an Object ID for one record in your layer, the Relationship ID: is the first number (0) in the text you posted, the Out Fields: just use *, and click the get button.
I don't have a good clue on that.
GoodDay
I am currently in the process of developing an enterprise GIS application and I am having problems as it relates to querying using the eSearch widget. All queries using ESRI’s basic search widget works , however any query using the eSearch widget hangs if the number of returns to the query is > 3000.
All other queries on the same field using the eSearch widget are successful. I have used the ‘repaired geometry’ tool on the data-set in question but it still does not work. Could you please assist. This problem has been occurring for months. I am desperate for a solution and any guidance would be appreciated.
There is a setting in ArcGIS server that usually limits returned records to 500 or 1000, you can check this. Also I would make sure the field in question is indexed.
There is a new thread for this subject.
Enhanced-Search-Widget-for-FlexViewer Part III | GeoNet
Cheryl,
Peter has some good points there. I sounds like you may have already adjusted the servers max records property if you are getting near 3000 though. This thread was closed in the old forums in favor of the new thread Peter has linked. Some how in the move to GeoNet this thread was reopened.
If you can post your eSearchWidget.xml in this link Enhanced-Search-Widget-for-FlexViewer Part III I can look at the issue.
Timothy Hales is it possible to close a thread to future comments as it was in the old forums? I had gotten Jim to close this thread due to size.
Robert, I have re-closed this discussion.
