Glen, If you don't do a date range can you get a single date to work?
Lixin, This is default behavior for Polylines that only have two points as there is no easy way to calculate the mid point on client side. If you search a polyline that has more than two vertexes than it will use a vertex that is closest to the middle.
A Hay, I want to be sure of the work flow before I can determine a LOE (Level of effort) and decide on the enhancement request.I am just not following what you are asking (things seem pretty straight forward when you understand what the flow is). You are going to have to break it down in more detail for me.
protected function results_click(event:MouseEvent):void { var o:Object = myResults.selectedItem; if(o){ selectedAddress.text = o.Address; myResults.visible = false; myResults.height = 0; dispatchEvent(new Event("addressSelected")); stage.focus = null; } }
protected function keyUp(event:KeyboardEvent):void { //Calls webservice when input reaches the 2 character minimum and webservice is loaded if (selectedAddress.text.length>2 && wsLoaded){ mySvc.addEventListener(ResultEvent.RESULT, searchResults); mySvc.addEventListener(FaultEvent.FAULT, fail); mySvc.findAddress(selectedAddress.text); } }
protected function init(event:FlexEvent):void { mySvc = new mx.rpc.soap.WebService(); mySvc.wsdl = "http://yourservice/xyz.asmx?wsdl"; mySvc.loadWSDL(); mySvc..addEventListener(LoadEvent.LOAD, load_listener); }
